trick z1000
- Ginger Bear
Made a bit more progress today, I have taken a 45mm x 30mm piece off billet to have a chanel milled through the centre of it. Then i will be able to shape it to fit in the swingarm. And get it tig welded in. The rear peg brackets are welded on now so apart from welding a mount for chain tensioner its done finally!!!!!!!!!
- Ginger Bear
