Harris Magnum 1
#46 PostAuthor: Pigford » Wed Nov 09, 2011 5:44 pm
Had an email back from Oliver at Harris Performance.........
Hi Mark,
The Magnum 1 and 2 are virtually identical but your frame is the Magnum 1.
I have sent you an appropriate dating letter.
I see a single sided arm has been fitted. Looking at your shock position and angle you may have difficulties finding a shock spring firm enough to make it work. It will need to be approximately double the stiffness of the original Mag 2 spring. I would estimate at least a 150Nmm spring would be needed, maybe more.
A rough method for calculating required spring weight is to measure the shock length when the wheel is on the ground, then measure the shock length when the wheel is at full bump. This gives the shock stroke. The required spring rate in N/mm is approximately 5000/stroke.
#47 PostAuthor: Pigford » Thu Nov 10, 2011 8:21 pm
YeeHaa - they arrived today :twisted:
Just awaiting my new swingarm (not the standard Harris item).... :!:
#48 PostAuthor: Rich » Fri Nov 11, 2011 5:33 pm
You'd better put some serious ponies in the engine to push those around :D
Padders
#49 PostAuthor: Padders » Fri Nov 11, 2011 6:21 pm
Ignore him Rich he's just showing off. :(
#50 PostAuthor: Pigford » Fri Nov 11, 2011 6:51 pm
As luck would have it, the front wheel came with the axel - and it fits straight on my ZZR1100 forks :P Just need to make an extra 12mm spacer as I won't be using the speedo drive.
Unfortunately (and you probably won't believe me) one of the disc carriers has taken a "whack" and the disc has a 5mm run-out now :?? SO I may just have to have 1 x disc up front :twisted: :twisted: :twisted:
#51 PostAuthor: ADRIAN H » Fri Nov 11, 2011 6:58 pm
You love single discs. Would love to build one of these, you beat me to it. Love the wheels. :lol: :lol: :lol:
#52 PostAuthor: Pigford » Fri Nov 11, 2011 7:17 pm
ADRIAN H wrote:You love single discs. Would love to build one of these, you beat me to it. Love the wheels. :lol: :lol: :lol:
Must admit a Harris/Rickman/Spondon/Martin, etc has been on my "Want List" for many years.......... and as this was only down the road from me (& you :wink: ) it was too good to turn down :wink:
#53 PostAuthor: paul doran » Fri Nov 11, 2011 7:35 pm
Pigford wrote:As luck would have it, the front wheel came with the axel - and it fits straight on my ZZR1100 forks :P Just need to make an extra 12mm spacer as I won't be using the speedo drive.
now there is a surprise :lol: :lol:
#54 PostAuthor: Pigford » Fri Nov 11, 2011 7:49 pm
:wink:
Also got the "dating" letter from Harris today :P
I also got my new headstock bearings so Pingu can make up my new yoke stem now.
My new swingarm (eBay) should arrive early next week ........ it's just soooo exciting :twisted:
HowieD
#55 PostAuthor: HowieD » Mon Nov 14, 2011 8:53 am
Pigford wrote:Yes GB, I'm very happy with it (cheers Jerry)
Saw this and thoght it was rather lush :twisted:
:P
are there any more pictures of this lushious beastie ???
#56 PostAuthor: Pigford » Mon Nov 14, 2011 5:29 pm
HowieD - I shall have an update of some more scintilating blingy stuff v. soon :wink:
Hows yous shaping up by the way :lol:
uk kev
#57 PostAuthor: uk kev » Mon Nov 14, 2011 10:16 pm
Damn that new JMC looks Sweeeeeet :wink:
HowieD
#58 PostAuthor: HowieD » Tue Nov 15, 2011 2:52 am
Pigford wrote:HowieD - I shall have an update of some more scintilating blingy stuff v. soon :wink:
Not much progress as I've been in Azerbaijan earning rebuild tokens!!
That Green Beautie made me have a rethink about making do and men tho!!!!What a well built machine. I would love to see it without the tank & seat.
H :lol: wie
#59 PostAuthor: Pigford » Tue Nov 15, 2011 10:46 am
So, heres the latest regarding the "running gear"..........
I've also ordered a new pair of wavey discs - so I shall be going twin stoppers up front :wink:
Padders
#60 PostAuthor: Padders » Tue Nov 15, 2011 11:26 am
:rocks
