New Project 2011/2012 /2013/2014!!
z1000puddin
REARSETS DONE
#46 PostAuthor: z1000puddin » Thu Dec 27, 2012 8:07 pm
Managed to get the rear sets all up & working fine.
These are Raask pedals & the rest is home made.
I am not 100% happy with the rear brake adjuster off of the master cylinder. I may change this as it just doesn't look right
Zed til Dead
z1000puddin
#47 PostAuthor: z1000puddin » Thu Jan 10, 2013 10:16 pm
Nothing much happening the last couple of weeks as now waiting to recieve the mandrel bends from dave at exhaust craft so I can finish up the zorst
Should be with me by monday/Tuesday.
Si has the body work and cant wait until I get this back.
Decided to do a bit of tally up :shock:
The main spec I decided to type out as I was struggling to remeber what year the bloody rear caliper was off of :oops: (GSXR1000 01/02) So I could order up new pads.
Spec is as follows
KAWASAKI 1075
STANDARD UNMODIFIED ZED THOU FRAME POWDERCOATED BLACK.
GSXR750 FORKS EXTENSIONS BY OWNER -POLISHED
LESTER MAG WHEELS POWDER COATED
BILLET YOKES TOP ALUMINIUM POLISHED, BOTTOM STEEL POWDERCOATED
ZED THOU STEM
ZED THOU CLOCKS WITH WHITE DIALS
REPRO HANDLE BAR SWITCH UNITS
GPZ900R BRAKE/CLUTCH MASTER CYLINDERS/LEVERS POLISHED
ZED THOU LTD SHORT FRONT MUDGUARD
GSXR 750 NISSIN FRONT CALIPERS
VENHIL CARBON BRAKE LINES
ZED THOU CASINGS/ BARRELS
ZED 900 HEAD PORTED & POLISHED
STANDARD VALVES
MTC 1075 PISTONS & TEFLON BUTTONS
ANDREWS 2X CAMS .360 LIFT
UNDERCUT GEARBOX
FALK STRUMM HYDRAULIC CLUTCH CONVERSION
MIKUNI VM 28 CARBS- Now changed to 29mm smoothbores
DYNA COIL
Dyna Inition
TAYLOR LEADS
EXHAUST CRAFT 4-1 STAINLESS STEEL & LINK PIPE, (BAFFLE & TWIN OUTLET BY OWNER)
REAR SETS BY OWNER
GSXR1000 SWING ARM ( MODIFIED TO TWIN SHOCK BY OWNER)
GSXR 1000 REAR CALIPER
KONI DIAL A RIDE SHOCKS
STAINLESS STEEL REDUCED HEIGHT BATTERY BOX
NEW ALTINATOR & COMBINED REG/REC UNIT
MOTBATT BATTERY
ALUMINIUM SEAT BASE ( FOAM & LEATHER COVER BY GRAMPIAN UPHOLSTERY)
REAR TAIL PIECE BY OWNER
LED REAR LIGHT
STANDARD ZED THOU TANK & SIDE PANELS
ALL POLISHING BY MIKEY
PAINT WORK BY FLYING TIGER PAINTWORK
ALL FASTENERS STAINLESS STEEL
Zed til Dead
z1000puddin
#48 PostAuthor: z1000puddin » Mon Jan 21, 2013 8:36 pm
Well I couldnt put this off any longer, I was hoping for a bit warmer weather, as it is bloody freezing in me garage, even with the heaters on. :|
I received my 2 over length mandrel bent link pipes & couplings from Dave (Exhaustcraft)
I knew this was going to be tight & it was,
I decided to tack the pipes in situ, thinking this would be easier.But in hindsight I would have been better doing it on the bench.
I had my Invertor TIG plant Newark RT2000 home from work, but I forgot to take the stubby cap, so with a long cap it was bloody awkward getting access in the back of the frame tubes.
I have a slight misalignment on the connector just before the baffle box but this wont be seen as it is hidden behind the frame tubing.
Tacked up a small bracket, which will bolt onto one of the the existing center stand lugs.
So I dismantled the two sections & will get them welded up at work tomorrow.I will also fit a couple of stainless steel springs/lugs onthe bend just before the baffle box.
Once I receive the paint set from Si, I will finish of the twin outlet tail pipe.
That just leaves the ceramicoat to be done.
Zed til Dead
z1000puddin
Rear Brake
#49 PostAuthor: z1000puddin » Mon Feb 04, 2013 9:11 pm
Decided to get the rear brake cylinder adjuster sorted out.
I think this looks better ...
12mm ally 6082t6
Machine tapped M8
Drilled & counter bored, with a 1mm spot face to take the 16mm dia. ally bar that connects to the pedal.
I think I will just polish up & leave it.
Zed til Dead
#50 PostAuthor: paul doran » Mon Feb 04, 2013 9:37 pm
Stu it looks awesome
Re: Rear Brake
#51 PostAuthor: chrisNI » Mon Feb 04, 2013 9:50 pm
z1000puddin wrote:Decided to get the rear brake cylinder adjuster sorted out.
That's definitely better... :D coming along nicely now :D :D
zmaxmotorsports
#52 PostAuthor: zmaxmotorsports » Mon Feb 04, 2013 10:46 pm
Nice work :)
10-72 (build date)z1/2-74 z1s/2-75 z1s/77 1428 turbo/77 1170/78 1170/74 z1 1385 turbo nitrous project/80 1000ltd 1327 z1 clone.........
That ol kaw was fast on the draw
Outgunned suzukis and outrunned the law
zmaxmotorsports
#53 PostAuthor: zmaxmotorsports » Tue Feb 05, 2013 2:53 am
What would be a source for finding the basic 4n1 part of that header youve got there? :wink:
z1000puddin
#54 PostAuthor: z1000puddin » Tue Feb 05, 2013 7:15 am
zmaxmotorsports wrote:What would be a source for finding the basic 4n1 part of that header youve got there? :wink:
The 4-1 header & collector was made by one of the guys on here named Dave Yeowart
http://www.exhaustcraft.co.uk/
Zed til Dead
zmaxmotorsports
#55 PostAuthor: zmaxmotorsports » Tue Feb 05, 2013 4:28 pm
#56 PostAuthor: Rich » Tue Feb 05, 2013 8:47 pm
Brake lever - have you thought about moving the cylinder to give you a straight push or a cranked arm , rose joint on the lever?
steve bowdler
#57 PostAuthor: steve bowdler » Tue Feb 05, 2013 8:50 pm
Do not like the exhaust !
But if you want to get rid of it give me a shout :lol:
Seriously looks fantastic hope to get to hear it , great work mate :D :D
z1000puddin
#58 PostAuthor: z1000puddin » Tue Feb 05, 2013 9:14 pm
Rich wrote:Brake lever - have you thought about moving the cylinder to give you a straight push or a cranked arm , rose joint on the lever?
Rich,
I did look at that option, but having the cylinder angled up, just didnt look right with the mount plate lines.It kinda threw everything all to cock.
The pushrod that goes into the cylinder does pivot/swivel, so I do have a small amount of free play.
The rear brake works well as it is but I still need to fit a M8 lock nut
stu
Zed til Dead
z1000puddin
#59 PostAuthor: z1000puddin » Tue Feb 05, 2013 9:22 pm
steve bowdler wrote:Do not like the exhaust !
Steve,
Dave at exhaustcraft had done a fantastic job with the 4-1 & the collector,
I just need to tell everyone that the link pipe & the rest was down to me as it is not as perfect as Daves work- my TIG welding isnt what it used to be (been off the tools too long) :oops:
I should have got one of my welders at work to do the welding, it might have blended in better with daves work.
I actually fitted a variable baffle inside the rear box ( just for Mr MOT man)
So when it is baffled closed it is quite normal.
But with it fully open it has a great sound :shock: :shock: :D
Zed til Dead
z1000puddin
PAINT TEASER[IMG]http://i956.photobucket.com/albums/ae44/stu
#60 PostAuthor: z1000puddin » Fri Feb 15, 2013 10:11 pm
More pics to follow :D
stu
Zed til Dead
