Baby H**** Commuter - Cafe Racer project!!!!
- paul doran
Spent the morning checking out the motor - wouldn't turn over with the kickstarter. I took the plugs out last night & tipped some red diesel in to soak. Tried turning it over this morning - nope
Removed the sump plug and what looked like 2 pints of deisel fell out. So decided to check under the clutch cover.....
....that shitty looking lump in front of the clutch is the oil pump !!!!!!
Must have had a "damp problem" during tis 22 yr lay-up! So lets check it out properly..... engine out & get the head off....
That all looks good..... next the barrels..... check the pistons too....
The R/H con rod is a bit "notchy" on the crank
Pigford wrote::evil: Think I was ripped off
The R/H con rod is a bit "notchy" on the crankso thats it - end of my dreams
eBay for this little Hondor
Sorry to see the engine is shagged. Better luck next time eh.
- Ginger Bear
- paul doran
