Cam Timing Help - Please
#46 PostAuthor: Pigford » Tue Dec 16, 2008 7:35 pm
Rich wrote:You can slip a tooth on "proper" chain Zeds, you know those with the square covers and proper crank :D just rotate it backwards without a tensioner.
Don't bother to take the sprockets off the cams you don't need to.
Check the valves haven't had the tips ground when you take them out, check installed height when you put new ones back in.
Rich, take it easy with the Technical Stuff, Bill's not a qualified mechanic... :roll:
#47 PostAuthor: Rich » Tue Dec 16, 2008 7:43 pm
I did I didn't put it in bold
tlc
#48 PostAuthor: tlc » Tue Dec 16, 2008 7:49 pm
There you go Chrisu..................with your inferior engine design. :lol:
