Z1000 MK2 - Poor running in the 2-3000 rpm range
njwmct
#61 PostAuthor: njwmct » Mon Sep 01, 2014 3:40 pm
Finally Sorted:
At long last the MK2 is running how it should be:
Starts on the button from Cold & Hot
Idles nice both on choke from cold & once warmed up.
Pulls nicely from idle.
No hesitation at 2-3000 rpm & no surging on a constant throttle
Pulls like a train up through the rev range.
For those that have followed this thread & offered advice - many thanks.
In case it's of use to anyone else, here is the final set up of the VM28SS carbs:
All jets are genuine Mikuni items
Needle jets #258 O-1
Standard needle clip position 3 with 0.48 mm shim under clip to give an effective position of 3.5
Standard Main Jet #105
Pilot Jet #17.5 (standard is #15)
Carbs balanced very carefully to maximise vacuum
Idle mixtutre set up with colourtune plug to give a bunsen blue flame just as yellow disappears which resulted with pilot air screws at the following turns out:
Cyl 1 - 1&1/4
Cyl 2 - 1
Cyl 3 - 1
Cyl 4 - 1&1/8
Just need to get a few miles on it now - if we get a bit more Summer !!!
:D :D :D :D
Z1Boy
#62 PostAuthor: Z1Boy » Tue Sep 02, 2014 2:09 pm
Well done and thanks for the update. Glad its all sorted.
If at first you don't succeed, try and try again. Then quit. There's no point in being a damn fool about it.
W C Fields
jimmock
#63 PostAuthor: jimmock » Tue Sep 02, 2014 3:14 pm
I just love a happy ending.
:lar :hur2 :hurr :tra
Jimmock. :wnkr
I hate people I don't like !
Users browsing this forum: No registered users and 151 guests
