Z from the dead....
Simonh
#61 PostAuthor: Simonh » Mon Feb 01, 2016 8:08 pm
Another fine mess I've got myself into!
Simonh
#62 PostAuthor: Simonh » Mon Feb 01, 2016 8:11 pm
I've ordered all OEM 'O' rings this evening from Cradley Kawasaki for when i put them back together.
should look great!
Can anyone tell me what the original factory Finnish should be on the top mixing chamber and float bowls?
should they be polished?
Simonh
#63 PostAuthor: Simonh » Fri Feb 19, 2016 7:30 pm
carbs are all together now, i think they look ok for an amature :lol:
apart from seals and gaskets i decided to replace the float valves (not full assebly as they were £40 each), i had ordered some off eBay but when they got here i decided they were going to cause me problems further down the line and just looked crappy, so ordered 4 genuine mikuni ones... £16 each.... :shock:, hey ho
Simonh
#64 PostAuthor: Simonh » Fri Feb 19, 2016 7:35 pm
tlc
#65 PostAuthor: tlc » Fri Feb 19, 2016 7:51 pm
Your carbs look good. They do dull down in time.
These were vapour blasted.
Simonh
#66 PostAuthor: Simonh » Fri Feb 19, 2016 8:00 pm
they look great... I'm ok with it dulling down, id rather it not look "bling"..and more original
ps who can spot the rookie error....??
PAULJAC47
#67 PostAuthor: PAULJAC47 » Fri Feb 19, 2016 8:06 pm
Not a bad job,do you mean the little rubber pipes missing from the carbs that link the two bodies together or the corrsion re appearing near the adjuster? just doneas thou set and an a4 set meself!
Simonh
#68 PostAuthor: Simonh » Fri Feb 19, 2016 8:11 pm
first prize :oops:
i also forgot to put the T pieces in...so had to pull them back apart again...
corrosion on the top bracket il have to live with, its been neglected has this old girl and thats how it came back from zinc plating
tlc
#69 PostAuthor: tlc » Sat Feb 20, 2016 12:08 pm
Carbs 2 & 3 mixed up.
You'll find out when you try and put the t pieces in.
#70 PostAuthor: Garry.L » Sat Feb 20, 2016 12:51 pm
tlc wrote:These were vapour blasted.
I absolutely love that 'just blasted' look Chris, but even with my best efforts they dull down....... sadly. :(
Simonh
#71 PostAuthor: Simonh » Sun Apr 03, 2016 7:25 pm
so a few updates on the old girl,
carbs eventually fitted... jeez it wasn't easy, look good though
Simonh
#72 PostAuthor: Simonh » Sun Apr 03, 2016 7:27 pm
also got the paint back from mark hutchinson, and boy was it with the wait, so glad i waited and found mark... the man is a genius, everything i hoped it would;d be
Simonh
#73 PostAuthor: Simonh » Sun Apr 03, 2016 7:31 pm
i couldn't wait to put them on the bike to see how she looked, thankfully it was a sunny day...and really showed the quality of the paint
jobImageImageImage
Simonh
#74 PostAuthor: Simonh » Sun Apr 03, 2016 7:39 pm
even though progress has been good and it all looks like its coming together I'm starting to hit a wall.. I'm finding it difficult to bring it all together, and worry about all the parts working as one, I'm really frustrated with the electrics as i haven't got a clue really, i keep looking at the wiring diagrams but i struggle to understand them (probably easy to most of you)
once again I'm at a point where i question weather i can be bothered to Finnish it.
this thing has seriously worn me out
Fred the Zed
#75 PostAuthor: Fred the Zed » Sun Apr 03, 2016 7:47 pm
Simonh wrote:even though progress has been good and it all looks like its coming together I'm starting to hit a wall.. I'm finding it difficult to bring it all together, and worry about all the parts working as one, I'm really frustrated with the electrics as i haven't got a clue really, i keep looking at the wiring diagrams but i struggle to understand them (probably easy to most of you)
Electrics are key to reliability. If you haven't the knowledge (like I haven't) then its worth getting a repro loom from ZPower or somewhere for peace of mind. Just saying.
Fred
Paid Up Member
