trick z1000
The head has been rebuilt new valve guides ect, barrels have been checked and honed i have fitted new weisco 1075 rings. I have done the timing. I have also done a compresion test just to make sure all is well before i get it back all back together and it is all good
So tomorrow i will get the rocker cover and exhaust on. Then i will get the carbs apart.
So tomorrow i will get the rocker cover and exhaust on. Then i will get the carbs apart.Spent this morning in garage fitting exhaust rocker cover ect. Did another comp test just to make sure and it's all fine!!!! Whilst stripping the carbs to find the main prob to why it was running on 3 cylinders i found the reason it reved up before it broke down was throttle slide balance screw had fallen out hence only firing on 3!!!!! It's all back together now I have just got to borrow my mates carb balancer and she should be up and running!!!!!
