That is as good as it can be done Realy looking forward to see you and the bike in germany
pertonpc wrote:Hi Bill
Coming on well now mate.
You mentioned refreshing the brake disc - did you re-finish the braking surface if so how was it done please?
Thanks from Mark
pertonpc wrote:
A nice set of 70's chrome valve caps with valve tools built in would be the finishing touch once the weights are sorted I reckon - then you'll be proper 1976 all over again
Ta from Mark
Paul M wrote:Hi Bill
your build is coming along nicely, have you got full details for the company that did the headstock sticker for you.?
Paul
MCZ900 wrote:Just a quick one you have your red live wire going to the opposite side on the solenoid mine goes into to bottom nut nearest the battery on both my bikes, does it make any difference?
