THE WIDOW SHAKER............................... What could possibly go wrong?
swampy
#76 PostAuthor: swampy » Thu Jan 26, 2017 3:47 pm
:D glad you like me sense of humour.
#77 PostAuthor: Ginger Bear » Thu Jan 26, 2017 3:49 pm
Yep, warped........like mine. :wink:
#78 PostAuthor: Ginger Bear » Sat Feb 04, 2017 2:38 pm
Progressed a bit more with this, welded my 'disc carrier' to the axle, then re-cut the face on the lathe to get it as square as possible.
Countersunk that pesky bolt that was fouling the chain.
Welded sprocket to the axle & fitted a centre support bearing.
Trimmed rear bodywork to fit. :D
#79 PostAuthor: Al » Sat Feb 04, 2017 4:28 pm
Stella engineering.
#80 PostAuthor: Pigford » Sat Feb 04, 2017 5:05 pm
Al wrote:Stella engineering.
Hit the Nail on the Head :P
#81 PostAuthor: Garry.L » Sat Feb 04, 2017 9:14 pm
....... or Stannah engineering.
#82 PostAuthor: Ginger Bear » Tue Feb 07, 2017 5:58 pm
Stripped it all apart, finished welding (or blobbing hot metal) on all the inaccessible bits, then gave it a couple of coats of hammerite Satin Black.
#83 PostAuthor: Ginger Bear » Sun Feb 19, 2017 6:32 pm
Re-assembled just about everything, mounted battery, solenoid, reg/rectifier and made a simple loom. Motor now cranks over 'on the button'. Just need to add an ignition circuit and we're ready to fire it up. :boom :boom
Z1parR
#84 PostAuthor: Z1parR » Sun Feb 19, 2017 7:47 pm
What could possibly go wrong :wink:
Loving it Steve :up :up
0172 . Geoff Parr
garyd
#85 PostAuthor: garyd » Sun Feb 19, 2017 9:02 pm
Hmmm...How sticky do you want that rear tyre to be??? :yay
#86 PostAuthor: ADRIAN H » Sun Feb 19, 2017 9:04 pm
garyd wrote:Hmmm...How sticky do you want that rear tyre to be??? :yay
Heat shield of some sort maybe ?
buzzard
#87 PostAuthor: buzzard » Tue Feb 21, 2017 11:55 am
Can't see the Nitrous bottle Steve.
Every man should have a shed (for bikes obviously..)
swampy
#88 PostAuthor: swampy » Tue Feb 21, 2017 8:24 pm
Just a wild stab in the dark here, but would not some go-kart wheels are tyres be a wise idea.
#89 PostAuthor: Ginger Bear » Tue Feb 21, 2017 9:32 pm
buzzard wrote:Can't see the Nitrous bottle Steve.
Give it time. :wink:
#90 PostAuthor: Ginger Bear » Tue Feb 21, 2017 9:37 pm
swampy wrote:Just a wild stab in the dark here, but would not some go-kart wheels are tyres be a wise idea.
Yep, they probably would, along with proper brakes & suspension. :??
It has been noted, that the original 'test pilot' Rozzer aka John Roscoe, seem's to have left the room! :D :D
Users browsing this forum: neilbarrett and 23 guests
