Can anyone identify the pistons ?
The numbers dont seem to be Wiseco
Lawson Jigsaw Project
- z1000puddin
Re: Lawson Jigsaw Project
- Attachments
- IMG_1206.JPG (105.19 KiB) Viewed 5444 times
- IMG_1203.JPG (100.11 KiB) Viewed 5444 times
- IMG_1202.JPG (63.97 KiB) Viewed 5444 times
Zed til Dead
- paul doran
Stuart
shims are under bucket on unitrack heads so it is correct
unusual to see broken shims
I had a smashed shim on a Z1 engine recently and a badly fitting bucket caused it
it would not compress when cam lobe struck it so something had to give and the shim shattered
paul doran wrote:unusual to see broken shims
I read somewhere (maybe on this forum?) that some people ground old shims down to a smaller size rather than buying new ones, and this was likely to effect their "hardness" and cause them to break.
Could be the cause, or an old wive's tale?!
2006 ZRX1200R
1982 Z400J project
ex owner of Z1100R
GXI 2752 are you out there?
1982 Z400J project
ex owner of Z1100R
I had a similar problem on my ELR, the stripped threads were over come by getting an engineering co. to install brass/bronze stud then mill flat and driil and tap to m6.
The lack of compression on mine was turned out to be partly down to a cracked valve guide, all guides then got replaced and head rebuilt with HD A.P.E springs as it gives me the optiom of hotter cams in future if i desire or deemed needed.
Just a thought ..... have they used the correct valve spring retainers for the shim under bucket ?
I believe they are different to the shim over bucket ones and maybe that broke the shims
I will stand corrected if that is not the case that they are different
