Can't find 4549, but have found these....
http://www.wiseco.com/ProductDetail.asp ... AppID=7203
Dig around a little more & you'll find exactly what you've got.
I'm not too sure ill be liked around here............
- Ginger Bear
KIT 1105CC KZ1000J / R, S523 CW17 4549PS XA/C2874 (+3.5 MM) W3918J
001-K1106
(+3.5 Mm) (+3.5 MM) W3918J
WISECO PISTONS:
This brand of high nottoriété we distribute since 1977 offering the largest range of forged pistons for motorcycles.
A passion for performance.
http://translate.google.co.uk/translate ... CDoQ7gEwAQ
001-K1106
WISECO PISTONS:
"nobody beats super a mart"
Even for garage work bench's..... Got a new dining table with one chair for $89!
I couldn't even buy the material to build myself a bench for that.
Where are my head studs you ask?
So I cleaned all the gaffa tape off my bearing surfaces and the next step is to clean all the glass beads out of the oil galleries, I don't wan any of those little bastards floating around!
I missed out on a set of Makuni flat slides on egay the other day they went for $280!
I'm sure someone here scored them....... But after thinking about it, I want to eventually
Use this bike as my daily ride so the The Mikuni BS34's I already have are probably better suited
To give me the smooth response I'll want.
So I pulled them down today, overall in pretty good nick! 2 split diaphrams and that's it.
A box of bits;
Soaked Emma for a while:
After a quick scrubb to get rid of the "all black" spray job some dickhead gave them:
They still need a good clean, Im deciding weather or not I'll buy a little ultrasonic cleaner.....
A box of bits;
So I picked up Betsy the parts bich today (not really many parts left.....) I'm pretty happy with what I scored but also a little confused
Here she is:
It's got whats left of an 1100 donk:
And someone has welded in some bracing and a lower engine mount that as far as I know the Z1000ST never had
So could this be a GPZ motor? Coz they have the second lower front engine mount:
They have also done the bracing down the back bone, bounes!!!
And I got my cast engine mounts!!!!!
Here she is:
