warren3200gt wrote:I don't know is the answer Zedhead! just decided to work!
Need to fine tune to sincro revs/leds. Only the ingnition and leds connected hence no idiot lights.
https://youtu.be/9C0Xv9h6HqU
Woooo hooo
, i think voltage spikes are killing the lm2917. I've had to change for a new one a couple of times already. I found this which suggests a different model is required for points.warren3200gt wrote::sad , i think voltage spikes are killing the lm2917. I've had to change for a new one a couple of times already. I found this which suggests a different model is required for points.
https://www.electro-tech-online.com/thr ... ic.106247/
If correct, is there an easy way to "dampen" the spikes into it? or do I need to rethink the whole circuit?
warren3200gt wrote:Thanks. It would appear that the guy in the electro-tech thread had a similar issue and changing the lm 2917 to the 14 pin version cured this. Although adding in a V regulator and a couple of changes to values of components would be much easier than a circuit redesign!
