Another Z650...
j.b
Re: Another Z650...
#91 PostAuthor: j.b » Sat Mar 30, 2024 6:55 pm
Nice to see these progressing :up
With reference to the clutch damper rubbers, I bought a few sets of viton replacement rubbers from turbosteve84 on the 750turbo website for £40 a set, iirc he’s in the states but shipped them without any problems and I’ve been using them withouts any issues.
The z650, z750, gpz750 and 750 turbo all use the same dampers even though the turbo used an uprated clutch basket.
There is also an eBay seller in the uk selling the damper rubbers at £45/set listed for a z650, although I haven’t tried them, they do look to be the same shape as the ones I bought from Steve.
Bevelhead
Re: Another Z650...
#92 PostAuthor: Bevelhead » Sun Mar 31, 2024 2:18 pm
Hi JB, the clutch has been modded now, but useful info on the new rubber inserts.
I bought a tank for my bike, at a very good price off Ebay, turned out it wasn't from a Z650 as advertised, but probably from a Z550 LTD. Eventually bought another in good condition, no rust, but a small dent just behind the tank badge. I'm told dealing with a dent is a lot easier than dealing with rust, so shouldn't be a problem when it goes away to be painted.
Made a bracket out of 4mm alloy plate to mount the ZX6R rear light. Now waiting to hear from the powder coaters that the yokes and swingarm are ready for collection, hopefully next week.
Got the engines cases back from Camcoat who gave them a tough heat dispersant ceramic coating, so loosely assembled the empty cases to see how they look.
Re: Another Z650...
#93 PostAuthor: chrisNI » Sun Mar 31, 2024 10:02 pm
Starting to take shape :D
Bevelhead
Re: Another Z650...
#94 PostAuthor: Bevelhead » Sat Apr 20, 2024 9:26 pm
Got the R6 yokes and ZRX1100 swingarm back from powder coating, with new bearings fitted they went on the bike after a bit of hassle. The R6 yokes are slightly slimmer than the old Z650 yokes, so needed a spacer below the upper yoke to make everything work as it should.
Bevelhead
Re: Another Z650...
#95 PostAuthor: Bevelhead » Sat Apr 27, 2024 8:13 am
Alloy struts fitted for now, just to keep the swing arm off the ground, R6 forks fitted, with painted lowers. Found a £15 dolly on wheels which works ok, good for 200kg, means I don't have to carry the bike in and out of the garage anymore, as it was getting a bit heavy.
Yamaha Gold Spots fitted, along with a front guard from a XJR1300. While the forks look the same as that of the R6, their mounts are slightly different, so will need a spacer and bracket to make it fit the R6 lowers.
Bevelhead
Re: Another Z650...
#96 PostAuthor: Bevelhead » Sat Apr 27, 2024 8:15 am
Despite the engine not having been run since 2000, it was in good condition with little apparent wear, except for one thing.. the splines on the output shaft were badly worn. The engine came from a bike that was fitted with lighter CMA wheels many years ago, and these wheels didn't have a cush drive. Either this or a loose sprocket must have caused the damage.
Since I intend to fit a 5.5 inch rear wheel and 180 tyre, I bought a complete transmission from a later ZR7S, which has a slightly longer output shaft, while being surprisingly cheap..
Worn splines on original output shaft
ZR7S transmission in case
With the two side by side, you can see that the ZR7S output shaft is indeed longer than the original.
Bevelhead
Re: Another Z650...
#97 PostAuthor: Bevelhead » Sat May 04, 2024 9:56 am
Working on the headlight mount and gauge mount, starting with simple template..
Test fit, this Koso gauge is only a tacho, won't be used, but at 80mm its the same size as the one the bike is getting..
Bevelhead
Re: Another Z650...
#98 PostAuthor: Bevelhead » Sun May 12, 2024 5:57 pm
Test fit of the R6 wheels before they go off to be coated, while gauge bracket done and now also needs to be ceracoated. Next need to make brackets for mounting the headlight.
ollie
Re: Another Z650...
#99 PostAuthor: ollie » Sun May 12, 2024 8:07 pm
Taking shape :up :v
Bevelhead
Re: Another Z650...
#100 PostAuthor: Bevelhead » Mon May 20, 2024 7:50 pm
Headlight brackets are now made in steel, painted and on the bike. Haven't fitted the the sealed unit yet as there are a couple of fasteners that need to be replaced, as they are the wrong size. The gold bars are just for setting up, they won't be used in the final build.
Bevelhead
Re: Another Z650...
#101 PostAuthor: Bevelhead » Thu Jun 13, 2024 4:02 pm
I was given the old rusty Harris Performance exhaust taken off the Z650 turbo bike. It was rusted through around the collector, and normally I would've binned it. But they are getting rare now, so I decided to restore it and use it on the green Z650F2. First the holes in the collector were blasted and welded, then the system was sent to a local specialist for a satin black heat retaining ceramic coating. Not a cheap option, but I'm happy with the end result.
Bevelhead
Re: Another Z650...
#102 PostAuthor: Bevelhead » Tue Jul 16, 2024 5:08 pm
Got the wheels back from powder coating, they are a bronze/gold, fitted used but good set of discs. Next need to fit new bearings, tyres and then the bike will be on its wheels at last..
Bevelhead
Re: Another Z650...
#103 PostAuthor: Bevelhead » Tue Jul 16, 2024 5:09 pm
Meanwhile, the Turbo gets a pair of 'eyes'.
ollie
Re: Another Z650...
#104 PostAuthor: ollie » Thu Jul 18, 2024 11:22 am
Those wheels turned out great :D
Bevelhead
Re: Another Z650...
#105 PostAuthor: Bevelhead » Sat Sep 21, 2024 8:55 pm
Came to fit the ZR7 gearbox into the GPz750 engine, only to find it doesn't fit. The bearings on the end of the shafts are a bigger diameter on the ZR7.
I think the old bearings will fit on the ZR7 shafts, but before I try, anyone know if this will work?
