carb needle clip position Z1A
floydsz1
#1 PostAuthor: floydsz1 » Mon Jun 22, 2009 8:41 pm
Just put a keyster kit in me carbs, whats the standard clip position for the z1A needles in the slides, The ones i took out were on the second one down from the top so i put the new ones in the same position. Book says 3rd but is it from the top or the bottom.
runs fine except when pulling away from a junction etc, it almost feels like its going onto 3. just seems a bit fluffy.Once on the move its fine. its got new plugs and everything else is new, dyna ignition etc. Not had chance to have a proper run out yet,
but will before weekend when im off to stoke to the triumph owners rally, should win best jap as me mates gs850 usually wins.
DogsbolloxofZ1B
#2 PostAuthor: DogsbolloxofZ1B » Mon Jun 22, 2009 9:41 pm
Manual is correct, 3rd down from top which is the middle one..
Did you change the jet needle too? Should be done as a matched set.
floydsz1
#3 PostAuthor: floydsz1 » Mon Jun 22, 2009 9:55 pm
Yes , changed the jet needle, did the whole lot, Got the kits from NRP, maybe i should move the clip down one then as its on 2nd from top.
