So....my z1000a2 with Harris pipe and pod filters isn't running quite right.
Firstly I should say that the carbs have been cleaned and balanced and I don't think the jetting is a mile out.
If you ride the bike gently it runs like a new one.
Starts on the button, hot or cold, ticks over lovely and revs clean as you like.
The problem is that if the bike is 'willing' at low revs it feels rather 'unwilling' when pressing on.
On a fairly open throttle, probably about 80/90mph it spits back through the carbs and feels as though it is working hard to hold that sort of speed.
It's very difficult to put into words....it doesn't mis fire, nothing really goes wrong (except spitting back) it just feels uncomfortable and a bit harsh at higher speeds.
Any mind readers or crystal ball gazers out there ?
Opinions please.....
- Ginger Bear
Monk
- Ginger Bear
Steve Cooke
- ZedHead
Check the ignition advance first of all, straightforward, if all's well there i'd look at fuel air.
I'm assuming along with the pod filters and performance pipe you rejetted accordingly and set it up or had it set up?
If not then this is the first port of call.
If you did then check for air leaks around the inlet manifold rubbers, have someone hold the throttle open and give the rubbers a good squirt of WD and see if the engine note changes.
If OK there i'd still suspect leaning out at high revs so you could try raising the needle a clip to richen it at wider throttle or jumping up another jet size, some performance upgrades often call for a needle with a different taper.
if you have access to a garage with an exhaust gas analyser you can get them to check the burn at high throttle, even better if they have a rolling road as you can do it under load, this will show if you're definitely leaning out.
A good pointer of leaning is when it bogs out under sudden harsh accelleration above about 6000rpm (ish).
oooh buggery,
knew I meant to add summat else to my above post, seeing the coils one reminded me.
Check your battery, make sure it's got good charge and the reg/rec is behaving and not giving too little or too much, (if it peaks at well over 15V or well under 13V either the reg/rec or battery needs attention, a duff battery not taking in charge, (one bad cell e.g.), will make the reg / rec work harder thereby killing the battery and overheating and knackering the reg/rec.
Usual battery checks, charge on a charger, check you're in the 12.5 - 13V area, leave overnight see if voltage drops excessively, do the same on to see if anythings causing battery drain.
Also, as the other poster said, check the coils, older units can break down under use and heat build up.
Not hard to check, one cam could be a tooth out
