GUYZ
AS THE TITLE SAYS CARBS WANTED MUST BE GOOD COND 28 MM Z1A 2 SCREW TOPS SEND DETAILS AND PRICE IF YOU CAN HELP . I AM BORROWING SOME AT THE MO FROM THE BEST ZED MECHANIC IN HULL MARTIN PARKER ( PROWLERZ1 ) IF YOU WANT WORK DOING. BUT I NEED TO RETURN HIS CARBS AS MINE HAVE BEEN PLAYING UP FOR A WHILE NOW
PHIL
28 MM STANDARD CARBS Z1A
International Rep
International Rep
