early z1 switch assembly
mick znone
#1 PostAuthor: mick znone » Mon Jun 29, 2009 9:39 pm
ive just bought a z1a right hand switch block off ebay. it has no buttons or switches on it. do the buttons and switches off the z1b fit straight on :?:
C Martin
#2 PostAuthor: C Martin » Mon Jun 29, 2009 10:25 pm
Yes they fit, i used a new pattern Z1B switch removed the switch casings and fitted the switches and wiring in to my Z1 casings, but you have to un- solder and re-solder the kill switch
Chris
mick znone
#3 PostAuthor: mick znone » Tue Jun 30, 2009 6:41 am
thats great, thanks Chris, very pleased about that, just bought an empty early switch block for £10 on ebay, DEAL :brav
Garn 1
#4 PostAuthor: Garn 1 » Wed Jul 01, 2009 11:59 am
Don't be too fast in fitting Z1B "guts" into the Z1/early Z1A handle-bar control switches. I have an idea you get caught with the starter button fibre contact plate, as well as the solder joints as mentioned above.... Let's know how you go? I will be interested to know, as I have a few early RHS switches in need of innings (guts).
RegardZ
Garn 1
#5 PostAuthor: Garn 1 » Wed Jul 15, 2009 9:41 pm
MickZ1A & C Martin, before this thread disappears into oblivion...
Have you confirmed that the right-hand side, new patterned Z1B innings will fit into early Z1 switch-block cases. I understand there is soldering and re-soldering involved. As mentioned before, I'm concerned about that starter button.
Any further comment(s) would be appreciated.
RegardZ
mick znone
#6 PostAuthor: mick znone » Thu Jul 16, 2009 1:08 pm
hi Garn, i have the outer casing now and am going to check it all over next week, if you can wait till then, i will bring this thread up, updating on the progress,
Garn 1
#7 PostAuthor: Garn 1 » Fri Aug 07, 2009 7:53 am
Maybe, I will pose an answer to my queries..., I know you guys are busy.
Let me say, I don't think you can interchange a Z1B RHS h'bar switch into a Z1 RHS switch cases! Correct me if you have an answer!
RegardZ.
mick znone
#8 PostAuthor: mick znone » Fri Aug 07, 2009 8:08 am
sorry Garn, i havent been in a zed frame of mind for a while, bit like Monk, fell out of love with it after it let me down a bit. now i have a van, ive just popped it back in the barn. i need to reaquaint myself with the Z. :rake
mick znone
#9 PostAuthor: mick znone » Sat Aug 22, 2009 9:01 am
ok Garn, im oredering a set of repro z1b switches from zpower, im going to give it a go this week, will post the out come.
Garn 1
#10 PostAuthor: Garn 1 » Mon Aug 24, 2009 11:30 am
Thank's Mick, I knew you wouldn't forget!
RegardZ ~ Garn
mick znone
#11 PostAuthor: mick znone » Mon Aug 24, 2009 6:18 pm
just waiting for the switches from zpower, no zed to try it on now, just doing it out of curiosity :??
#12 PostAuthor: Pigford » Mon Aug 24, 2009 6:42 pm
Mick, I thought you'd sold your Zed :?: :??
AL MARSHALL
switch
#13 PostAuthor: AL MARSHALL » Mon Aug 24, 2009 6:48 pm
hi mick,would you consider selling me the early switch.with or without your experiment.i would also buy the zpower switches from you. pm me if you are interested :D
trouble.......seek and ye shall find
www.z-clocks.co.uk
Garn 1
#14 PostAuthor: Garn 1 » Wed Aug 26, 2009 5:27 pm
This has been continued under heading "Z1b innereds into Z1 cases" .....
Thanks Mick Z1A.
RegardZ
