Z650B 1976
irhobotolo
Z650B 1976
#1 PostAuthor: irhobotolo » Mon Jul 06, 2009 7:06 pm
This is my early model Z650. I bought it four years ago as a project and its been in bits for most of the last 3 years. I have had a purge and its back together and on the road again....£1500 later.
I want it as near as possible to original spec and its not far away now.The reason for this post is that i need the bracket for the reflector on the back mudguard under the number plate. Have looked on Ebay for a while but no luck. Also i want rid of the horrible stainless brake hoses. I have a NOS hose for the top but need the 2 lower ones. Zpower want £90 which seems a lot and i am not sure if they would be original parts.The twin discs were fitted to the bike from new. Again everything on ebay except what I want. Are the brakes the same as Z1/A/B/Z900 ? so that i can widen my search.
The vinyl seat cover is over 30 years old and is still supple but has lost its "blackness". I have tried all manner of things from Halfords but wasted my money as its still the same. Is there anything other than "Hammerite" to get it black again !!! as a new cover is not an option.I know the seat looks okay in the picture but its not so good close up. Any ideas or info appreciated. Steve.
tlc
#2 PostAuthor: tlc » Mon Jul 06, 2009 7:31 pm
Brake pipes will be same as Z900 Z1000A1. Save a search for the reflector. Mine cost £12 :D
Absolutely beautiful bike by the way.
Don`t let the bogmen tell you any different :lol:
phil churchett
#3 PostAuthor: phil churchett » Mon Jul 06, 2009 8:06 pm
Steve,
this seller has some Z650 stuff on, might be worth sending a message;
http://shop.ebay.co.uk/merchant/tania4198
Be careful what you use on the seat, don't make it too shiny/slippy.
Have you tried Armor All?
Lovely bike by the way!
paulstrees
Brake hoses/pipes
#4 PostAuthor: paulstrees » Mon Jul 06, 2009 8:08 pm
Hi
Give Steve a call at Classic hoses 07853542739 , I paid £40 for both the top and bottom hose on a Z1 and they even have the replica part numbers on the rubber, he also does the replica steel pipes with the correct fittings.
Paul
zedrider
#5 PostAuthor: zedrider » Mon Jul 06, 2009 9:25 pm
i might be able to help with the reflector braket i will have a look tomorrow
zed
zedrider
#6 PostAuthor: zedrider » Mon Jul 06, 2009 9:31 pm
ps the z650 for 1976/77 was the b1 and came with a single brake disk the outher side had a chrome cover over the bolt holes . i have the chrome cover . if its of intrest . they went double disk from the b2 modle and the brakes went from infront of the forks to behind shortly after that . from memory .
zed
zedrider
#7 PostAuthor: zedrider » Mon Jul 06, 2009 9:34 pm
i also still have the single spliter for the brakes pm me if intrested
zed
irhobotolo
#8 PostAuthor: irhobotolo » Tue Jul 07, 2009 7:32 pm
Thanks for the response and the compliments. Still plenty to do on the bike to get it how i want it but its getting there !
Paul : If I cant get some genuine hoses soon will give them a try.
Chris: Thanks for the info. I suspected that brakes were the same. Will try to get 900/1000 parts. I have the reflector but not the bracket for it.
Phil: Have dealt with Tania before via Ebay. Will check it out. Amour all is good but the vinyl has marks which it doesnt mask. Trying to get a NOS seat from USA at present.
Zedrider: If you have a bracket, send me a PM. The bike was fitted with twin discs from new which was a factory option costing £45. I have spoken to the first owner and he told me this and i am therefore happy to leave them on. I have never been sure if its B1 or B2. The bike has its factory paint which is B2 but the handbook under the seat says B1 ?
zedrider
#9 PostAuthor: zedrider » Tue Jul 07, 2009 7:43 pm
mines b1 mate 1978 but far from standard . i`m off to look in the garage now for you
zed
tlc
#10 PostAuthor: tlc » Tue Jul 07, 2009 7:54 pm
B1 means round M/cyl and calipers in front
B2 means triangular cylinder and calipers behind.
irhobotolo
#11 PostAuthor: irhobotolo » Tue Jul 07, 2009 8:10 pm
tailiftchris wrote:B1 means round M/cyl and calipers in front
:D :D :D Thats it then. Its a B1. It was registered 1st August 1977 so I guess its one of the last ? I dug out an old magazine with B2 roadtest and there dont seem to be much difference between the models.
RB
Mine's a triple!
Re: Z650B 1976
#12 PostAuthor: RB » Tue Jul 07, 2009 8:54 pm
irhobotolo wrote:The reason for this post is that i need the bracket for the reflector on the back mudguard under the number plate. Have looked on Ebay for a while but no luck.
I am reasonably confident that I have about 50 of them :shock: Tenner inc post ?
Bug the hell out me by PM until I answer you (I'm just a tad busy right now) But I will go and look for the little beggars!
Lifes too short . . .
zedrider
#13 PostAuthor: zedrider » Tue Jul 07, 2009 9:03 pm
yep found it :-)
zed
#14 PostAuthor: paul doran » Tue Jul 07, 2009 10:50 pm
that's a cracker of a 650
Big Fluff
#15 PostAuthor: Big Fluff » Wed Jul 08, 2009 12:19 pm
Yes, an absolutely stunning example, well done :wink:
