carbs
flybo
carbs
#1 PostAuthor: flybo » Thu Jul 09, 2009 5:27 pm
hi. i am new to this site... and building a 1978 z1000 a2. the carbs are crap. wot other carbs can i put on?? i hear gsxr carbs are good...is this true..thanks :P
phil churchett
#2 PostAuthor: phil churchett » Thu Jul 09, 2009 7:40 pm
Hi flybo,
what is the problem with the carbs you have?
There are a variety of different carbs that can be used, [although fitment/setting-up/tuning is rarely straightforward].
Hopefully, someone with experience of fitting alternative carbs, will reply.
Have you looked in the "search forum"?
DDZ900
CARBS
#3 PostAuthor: DDZ900 » Thu Jul 09, 2009 9:09 pm
HI FLYBO ! i use either kawasaki gpz750 or gt750 shaft ,cv carbs but will after use bigger inlet stubbs from either z1000j/gpz1100/gpz750/gt750
tlc
#4 PostAuthor: tlc » Fri Jul 10, 2009 6:02 am
Flyboy, the best way to cure your problems are to sort the original carbs out !
What has been done to your bike and why are your current carbs giving problems ?
You may find that there are other problems that need sorting first, such as ignition or valve clearances.
I`m not far away from you and would be happy to take a look after you are sure you`ve got over the basic problems.
Maybe post some pics of your bike ............. `cause we`re all nosy :D
#5 PostAuthor: Ginger Bear » Sat Jul 11, 2009 10:26 am
Flyboy,
Here is a pic of a set of Mikuni Flatslides from an early GSXR (I think) fitted to a Z1000ST that I broke last year. You will notice that the float bowls don't sit level, as the Suzuki has a more inclined inlet tract, although I don't think that is a real problem. You should be able to pic these up for about £50-60 from ebay. The spacing is spot on, you will need some inlet rubbers from a Z1000J & you're sorted!
If you want to spend lot's more, then you could splash out on a 'proper' set of Mikuni RS Flatslides. Come in various sizes 34, 36, 38 & 40mm. These will cost you around £500......................... I plan to buy some of these, as soon as I can persuade my conscience to turn a 'blind eye' to a big hit on the credit card!
#6 PostAuthor: Ginger Bear » Sat Jul 11, 2009 2:00 pm
Whoops..... Here is the pic :oops:
nanno
#7 PostAuthor: nanno » Sat Jul 11, 2009 10:40 pm
GB,
do you have some notes on the Jetting with pods?
I am considering fitting a set of those to my Z1000A...
thx,
Greg
#8 PostAuthor: Ginger Bear » Sun Jul 12, 2009 7:53 am
Sorry Nanno, I have absolutely no idea........ I didn't fit these, or look inside, just flogged em.
Pigford will probably give you some idea of where to start. If he doesn't post here, Give him a PM
PJ
#9 PostAuthor: PJ » Sun Jul 12, 2009 8:11 am
tailiftchris wrote:Flyboy, the best way to cure your problems are to sort the original carbs out !
Oh no, Chris I've been cyber deleted!!
tlc
#10 PostAuthor: tlc » Sun Jul 12, 2009 8:17 am
PJ wrote:Oh no, Chris I've been cyber deleted!!
