Hello
Am I right to think my CSR is restricted, if so, anyone know how to derestrict ? cheers
Z650 CSR Import - restricted?
Hi Ian....... Where in Dorset you at.... I'm just south of Yeovil - Sherborne
I think the USA CSR only has the air bleed gissmo fitted to the cam cover.... which is best removed then you can blank the cam cover bits off
Apart from normal "restrictive" standard exhaust system & air box, I don't think theres anything else - per say
ianrobins
Great - thanks for the info my new purchase in need of a balance and only giving me hints of its full power!
I'm based in Dorchester - do you venture to Poole tues eve? Last time I visited 6/7 yrs ago it cost me £600 fine and 8 points!! But friends are trying to lure me back and I guess I'll be safer on 650.
Cheers again.
Cheers again.
