Project Z1RII restoration
kawamick
#1 PostAuthor: kawamick » Fri Jul 24, 2009 4:12 pm
It took 3 years to find all parts and bits to restore this wreck to a top Z1RII.
This is the starting basis.
Mick
'78 Z1R, '80 Z1RII, '76 Z2 Z750 A4, '75 Z1 AME chopper, '80 Rickman CR1000, `72 Z1, 2001 ZRX1200R
tlc
#2 PostAuthor: tlc » Fri Jul 24, 2009 6:35 pm
Well that looks like a pretty good basis there Mick.
I assume you had already started when these photos were taken ?
mick znone
#3 PostAuthor: mick znone » Fri Jul 24, 2009 11:55 pm
lets have a bit more imformation then Mick, on the edge of my seat here :pop
ted1r
post
#4 PostAuthor: ted1r » Sat Jul 25, 2009 9:58 pm
Come on Mick you can not give us so little information. we need more.
lots more photos ,please.
Ted
Ps I have dried out now from the heavy rain we got on the way home last sunday.
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
kawamick
#5 PostAuthor: kawamick » Sun Jul 26, 2009 8:44 pm
So it's going on.
Frame, swing arm,fork legs and other parts are powder coated.
I changed the powder coated fork legs to polished ones.
Checked out the damper cylinder, changed seals,dust caps, and oil.
Also the coated Z900 yoks to new genuine lower und top Z1R yokes.
Mounted new RH and LH head light brackets and guides.
Mounted a rebuilded and new painted master cylinder and brakle fluid reservoir.
Now the bike is on the right legs. Feets and shoes are coming soon.
Mick
Re: Project Z1RII restoration
#6 PostAuthor: paul doran » Sun Jul 26, 2009 10:50 pm
kawamick wrote:It took 3 years to find all parts and bits to restore this wreck to a top Z1RII.
Mick
don't You mean MK2?
kawamick
#7 PostAuthor: kawamick » Mon Jul 27, 2009 3:51 am
Mick
don't You mean MK2?
No Paul,Z1RII, but the seller put some MK2 parts on the bike.
Mick
kawamick
#8 PostAuthor: kawamick » Tue Aug 04, 2009 9:37 am
So, i was not sluggardly in the last days.
When i bought the rolling chassis,the seller told me that he changed the piston rings because the motor burned oil. Some kilometers after changing the bike burned more oil than before. Here is the reason
No problem, i took a used zylinder with pistons from a crashed MK2 with only 8500 km on the clock out of my storage rack.
I changed the worn cam chain parts,the sprockets and the top idler assy were in good shape,probably they were changed before.
When i removed the old hardened carb holders, the next surprise.
Ok also no problem, another grab in the storage rack for a good head.
Checked out the valve guides,grinding in the valve seats,and changed the valve oil scraper rings.
Ok, head on the zylinder, valves adjusted,new head bolds. ready
The old alternator was ok, but he don't looks trustable. So i took an better one, complete with cover
The carbs are ultrasonic cleaned.New float valves and seats,new jets.
Cleaned the airbox and mounted new air cleaner ducts
At the weekend i get the new tyres, Avon Roadrider
But i'm irresolute about the wheels.
I have 3 sets. LH is the original set. In the middle is a set of lester wheels and on the right side is a Melber wheel set. :roll:
Mick
#9 PostAuthor: Pigford » Tue Aug 04, 2009 6:17 pm
Great set of photo's Mick..... :twisted:
Melber get my vote :wink:
mick znone
#10 PostAuthor: mick znone » Tue Aug 04, 2009 9:11 pm
well that's a wheelie tough decision :ek
Reecy
#11 PostAuthor: Reecy » Wed Aug 05, 2009 5:31 pm
Mick
I guess wheel find out what Mick chooes later.
Doh!!!!
Reecy :oops: :oops:
#12 PostAuthor: paul doran » Thu Aug 06, 2009 10:46 pm
Mick go for the Lester's
ted1r
bike
#13 PostAuthor: ted1r » Fri Aug 07, 2009 4:57 pm
Lesters Mick. be different, its coming on nicely looking at your photos.
Ted
KE250
KZ1200
Puch Maxi
and me ol Granada
Big John
#14 PostAuthor: Big John » Fri Aug 07, 2009 8:04 pm
paul doran wrote:Mick go for the Lester's
Have to agree, Lesters look real good, only bettered by 3 spoke Dymags.
Geoff Meager
#15 PostAuthor: Geoff Meager » Fri Aug 07, 2009 10:33 pm
Yep .... Lesters for me too
Users browsing this forum: No registered users and 197 guests
