wanted rear brake disc
horsepower
#1 PostAuthor: horsepower » Sun Jul 26, 2009 1:13 pm
290mm rear brake disc needed bought one off ebay but its only 280mm so the 280mm is up for grabs if any one can help
thanks
Steve
hillbilly
#2 PostAuthor: hillbilly » Mon Jul 27, 2009 6:42 pm
how many holes,i have a disc but its only got 4 mounting holes.its 296 wide,about 7mm thick and says 6mm minimum thickness.also has o k i on the back.if that helps.
horsepower
#3 PostAuthor: horsepower » Mon Jul 27, 2009 6:52 pm
hi mine has four holes to i will try and post picture of disc if the same bar the size how much would you want for it and postage to north wales
steve
hillbilly
#4 PostAuthor: hillbilly » Mon Jul 27, 2009 7:00 pm
if its any good to you you can have it,i have a mate down angelsey way that might be able to drop it off to you,he lives near bangor,he has a music studio there.ps this one is drilled. :wink:
horsepower
#5 PostAuthor: horsepower » Mon Jul 27, 2009 7:06 pm
yeah mine is drilled to is there enough distance from the top edge to the first drill hole to take it down to 290mm if there is then yes would like it
hillbilly
#6 PostAuthor: hillbilly » Mon Jul 27, 2009 7:15 pm
id say just about,it might leave you about 1mm/2mm from the holes.the disc is 296mm if you want it.give me a pm your address and if my mate cant drop it off for you ile have to send it. :lol:
