Ted
Points cam
Points cam
Does the team think
that the heel of the points arm should be just touching the rotor or should there be a gap, I am at a loose end with my timing.
Ted
Ted
"Work this is why I did it"
KE250
KZ1200
Puch Maxi
Be careful with Pensions :e
and me ol Granada
KE250
KZ1200
Puch Maxi
and me ol Granada
Ted, the fibre heel should bear on the cam with some pressure from the curved steel blue spring strap. The points are controlled by the heel bearing on the this cam. If there is no pressure on the cam you will not be able to set the points to the required 0.015" odd! .... No gap ever between heel & cam!
Note: I have found some replacement points of the Z1/ Z900's are hard to set ... something to do with their dimensions ... maybe off a Z650!
RegardZ ~ Garn
RegardZ ~ Garn
- DogsbolloxofZ1B
post
Thanks but I have a 3mm gap tween points heel and rotor when points closed ,I think the rotors worn, has anyone else come across this b4?
Ted
Ted
KE250
KZ1200
Puch Maxi
and me ol Granada
KE250
KZ1200
Puch Maxi
and me ol Granada
- steve bowdler
post
Lost the plot with this timing, got it set bang on static runnig sweet, just been for a run going great till ,back homme i`ve two of the most beautiful blue down pipes and two normal.put strobe on bang on, plugs perfect colour, HELP
Ted
Ted
KE250
KZ1200
Puch Maxi
and me ol Granada
KE250
KZ1200
Puch Maxi
and me ol Granada
