swinging arm??
swinging arm??
hi im newbe to the site...i have a z1000a1. i would like to fit a zxr 5.5 180 rear wheel. to the back. and would like to no wot type swinging arm would fit with not to much mucking about??? any imfo would be great help..thanks brian..
ZRX1100 swingarm not too much bother only real work is to extend out the top shock mounts. If you are not too bothered about using the ZXR wheel you can fit the complete back end use an offset sprocket and your away. Check out the German Zeds in the meeting section a few of those have had the ZRX1100 swingarm fitted. Plus Chris in the projects section has had one fitted. Don't use the ZRX1200 as I had one fitted to a Zed I bought and its a bit too long and messes up the handling. Though if you are going up the strip its the one to go for. If you use the standard ZRX1100 rear shocks they are 365mm against the standard 350mm so lift the back slightly and look better.
Users browsing this forum: No registered users and 125 guests
