Z900A4 Reproduction seat
I've got 3 A4 seats, 1 badly bent in middle, other 2 badly cracked and cancer has set in around the edges. Any idea's were to buy a repo? Thanks Hench
- mick znone
mick z1a wrote:http://cgi.ebay.com/ebaymotors/New-SEAT-Kawasaki-Z1-900-Kz900-KZ1000-73-78_W0QQcmdZViewItemQQ_trksidZp4634Q2ec0Q2em14Q2el1262QQhashZitem25555f4bbaQQitemZ160346098618QQptZMotorcyclesQ5fPartsQ5fAccessories
I love how they add, "Made in Japan" in these adverts...
I never knew that Taiwan was part of Japan..
Dxyselia rlues, oaky.
http://www2.b3ta.com/youcantspell/
Thanks for the leads fellas, I've checked these sites and probably everyone in the world to no avail.
I'm amazed how many sellers list Z1/Z900A4/Z1000A1/A2 as the same-same, gets your hopes up, then what the f##k.
Good opening for a supplier to do A4/A1/A2 seats also A1/A2 orig. pipes, must be enough demand?
Hench
Hench
RGH wrote:Thanks for the leads fellas, I've checked these sites and probably everyone in the world to no avail.
Hench
Hench, not sure, but I thought you could fit the later lock catch onto these seats rather than the plunger catch?
PJ
A replica standard seat for the Z900/Z1000A1/A2. Will also fit the 900/1000 LTD models.comes with hinges/rubbers but NOT the U shaped catch. made in Japan to original specifaction. The cover is not quite right, more like the original z1 pattern.Comes as standard as the American/Export type without the strap however Please order the strap if you need one seperatly.
Available Options:
Seat strap kit (+$29.973a)
Click to enlarge
Thanks all, yes most repo seats take plunger and U bolt but
As can be seen above, all these seats have Z1 series pattern, works out bit expensive one of these plus an A4 repo seat cover, maybe only option.
Thanks again from sunny Aust. Hench.
Available Options:
Click to enlarge
