Newtronic ignotion failing? - is Boyer better?
1340fxd
#1 PostAuthor: 1340fxd » Sun Aug 02, 2009 5:30 pm
My 78 Z1000 has started mis-behaving on start-up. She caughs backfires and splutters when I first start her up after a couple weeks of not using her - I have two other bikes to keep happy, so the old Zed gets a run every couple of weeks :oops:
I think the problem is that the battery loses voltage over the period (it is a new battery but I can't trickle charge it as there is no electricity in my garage). After about five minutes of running, she clears and runs well. On re-starting after a run, she re-fires without problems.
The ignition is Newtronics who I think went bust so to solve the problem I'll probably get a Boyer system fitted. Their website show only "digital" ignition kits, whatever that means?
Does anyone have any tips or experience of the Newtronics system vs the Boter Digital stuff? :??
Dear Santa, please can I have...
FER
Auld Heedyun
#2 PostAuthor: FER » Sun Aug 02, 2009 5:34 pm
Get a Dyna system , miles better than anything else . Dyna S if money is tight , Dyna 2000 if you can afford it .
fer
phil churchett
#3 PostAuthor: phil churchett » Sun Aug 02, 2009 5:39 pm
To be honest, i haven't had experience of either of the systems you mention, but have known a few that have used Boyer. I can't think of anyone that would recommend them.
I am sure someone with more experience of electronic ignition, will post their thoughts. Many owners use Dyna ignition systems, usually with good results.
#4 PostAuthor: Pigford » Sun Aug 02, 2009 6:04 pm
Dyna wins...... every time :wink:
Newtronics (was Pirahna years back) aren't the best..... Good coz you can static time them (in a dark garage - out of the sunlight :?? ), but new manufactures may not be as sorted :|
Boyer is OK, but coz its magnetic triggered, can't be set static :evil: The plus point is they're UK based and quite helpful, but so are Dynatek :twisted:
Although theres plenty of people running Boyer - for the last 20+ years :roll:
Pays yer money, makes yer choice :!:
Steve R
#5 PostAuthor: Steve R » Sun Aug 02, 2009 8:17 pm
As Fer said Dyna is probably the best.
Have you considered something like this?
http://www.theultimatefinish.co.uk/icp- ... arger.aspx
1340fxd
#6 PostAuthor: 1340fxd » Sun Aug 02, 2009 8:28 pm
Thanks guys - looks like a new Dyna 2000 it will be. I like the idea of the solar charger but in an underground garage that could be a bit of a challenge. :)
FER
Auld Heedyun
#7 PostAuthor: FER » Sun Aug 02, 2009 9:05 pm
Talk to Jeff at Z1 Enterprises for the Dyna .
fer
Geoff Meager
#8 PostAuthor: Geoff Meager » Sun Aug 02, 2009 9:27 pm
Had Boyer fitted on the A4 when I bought her ........ absolute sh*t
Changed over to Points after two weeks :D
