if i take the 3yellow wires from the alternator to the unit then the red to pos and the blacks neg of the battery
charging
MAC777
charging
hi, i have a 77 z1000 which charges at15/16 volts tried a reg still the same so i thought i would try a reg/rect from a blackbird i got a new unit from somewhere ,would this work?
Mac777, the fact that your blackbird reg/rect unit has 3 yellow wires is a start, that means it has three wires coming from the alternator. I beleve you will be able to get it working, however, you won't have a switch circuit. the replacements need a 6 wire reg/rect.
RegardZ.
RegardZ.
- Ginger Bear
