I thought this would be a simple job but it is turning into a nightmare. I am sorely tempted to fit my K&N's but I am trying to use that as a last resort.
Mart
hal wrote:Been down this road with my z1b
i resorted to getting e new craft knife blade and slightly chamfering the air filter inlets so they slide over the sharp edges of the carbs, also its easier if you remove the battery box because then you can get your hand behind the air box to give it a push, using a silicone spray like back to black also helps.
zedrider wrote:one thing ive done in the past to get stiff ones back on is to warm them with a hair dryer . if you fit new ones try coating the inside of them with vasaline . hope this helps .
durhamz1b wrote:PAULJAC47 wrote:Get some silicon spray like dashboard cleaner put rubbers into a plastic bag fill with the silicon spray and leave for a couple of days with top tied this sometimes works quite well Cheers Paulj..
