Neumáticos
Neumáticos
Just a dumb arsed question.. but when your rear tyre is worn do you replace both front and rear at the same time even though your front is like new, and do you replace both with the same make?
Lost in the desert somewhere
As Chris say, best practice to keep same make/type tyres on bikes - But in the real world its usually not a problem with different makes. Try to avoid radically different profiles each end.
Some say Zeds handle bestest with a ribbed front tyre - track truer & steadier
The way these old things handle, at least you ain't gonna spoil there razor sharp, well balance handling manners
i agree bt45's are great tyres fitted to all my zeds ,, only 1 snag i had to send one back to bridgestone a front less than 1500 miles on it and only 7 months old real bad cracking inside the treads (nearly failed mot ),,, bridgestone aledgedly tested it twice and came up with the same ole get out clause been run either over or under inflated ,, would not replace it tyre was date coded 2008 so maybe a bad batch
73 z1 green
73 z1 brown
74 z1a brown
75 z1b red
75 z1b blue
76 z900 green
77 z1000 black
Zrx1200r
73 z1 brown
74 z1a brown
75 z1b red
75 z1b blue
76 z900 green
77 z1000 black
Zrx1200r
