ENGINE OUT
Z1Barrie
ENGINE OUT
#1 PostAuthor: Z1Barrie » Sun Mar 11, 2007 12:22 pm
What is the best way to get the engine out of my z900 without scratching any paintwork ect and is it a job i can do myself or is the engine to heavy
baz
Jeff Saunders
#2 PostAuthor: Jeff Saunders » Sun Mar 11, 2007 3:17 pm
they are very heavy - around 220lbs - you really need two sets of hands to do this.
What helps is removing the cam cover and exhaust studs. If you plan on pulling the head, do that before removing it from the frame. You can also drain the oil, pull the oil filter, filter cover, oil sump and oil pump from the engine before removing from the frame.
If you plan on totally pulling the bike apart for refurbishment, then when you reassemble, consider not putting the engine into the frame, but rather the frame over the engine - you lay the engine on it's side (on padded blocks, and lower the frame over the engine.
ROZZER
#3 PostAuthor: ROZZER » Sun Mar 11, 2007 8:52 pm
I removed my motor recently and to protect the frame I taped corrugated cardboard to the frame rails with copious amounts of gaffer tape which worked at treat with no damage whatsoever. As Jeff said, the motors are heavy and it took 2 pairs of hands and a trolley jack under the sump to get mine out then back in again. Removed and installed mine whole cos my engine builder will only work on motors out of the frame, so its possible to do it but far easier/lighter if you remove the head/barrels first.
AKA John Roscoe. PUM #028
1975 Z1B, 1980 Yamaha 350LC
Users browsing this forum: No registered users and 77 guests
