Smokin on over run
Z1000ELR
Smokin on over run
#1 PostAuthor: Z1000ELR » Wed Aug 19, 2009 10:50 am
The beast is smokin a bit on over run. Im told its the valve seals that need replacing. How easy is this or would i be better off getting it done?
Si
BShaw
#2 PostAuthor: BShaw » Wed Aug 19, 2009 1:31 pm
Probobly valve guides, you can DIY,(I have) but depends on your spannering ability, you need an oven big enough for your head, a drift and a reamer. Either way it's a head off job.
Baza
Z1000ELR
#3 PostAuthor: Z1000ELR » Wed Aug 19, 2009 3:14 pm
OK Thanks
BShaw
#4 PostAuthor: BShaw » Wed Aug 19, 2009 3:47 pm
If you are going to do it give me a bell my number is in the mag.
Baza
Z1000ELR
#5 PostAuthor: Z1000ELR » Wed Aug 19, 2009 4:32 pm
Will do Baza
Si
GEZ635
#6 PostAuthor: GEZ635 » Wed Aug 19, 2009 10:15 pm
You should also re-cut the valve seats if changing the guides.
Gez
Gez
