Rickman rear sprocket help
kenif
#1 PostAuthor: kenif » Fri Sep 04, 2009 1:24 am
Hi Guys,I am looking at replacing the rear sprocket on my CR and was hoping one of you kind gentlemen could tell me the distance between bolt holes on a standard Z900 sprocket ,the sprocket I have at the moment has bolt holes at 65mm apart, I am unsure if the Rickman rear hub(wire wheels)will take a standard kwaka sprocket ,the one I have appears to be machined out to fit the Rickman hub.Cheers Ken.
Steve Cooke
#2 PostAuthor: Steve Cooke » Fri Sep 04, 2009 5:09 am
Yes it is 65mm centres.
kenif
#3 PostAuthor: kenif » Fri Sep 04, 2009 7:31 am
thanks Steve,I guess I will have to get a standard one machined to fit my hub,I'm interested to know what others have done or recomend.Cheers Ken.
stevemc
#4 PostAuthor: stevemc » Sun Sep 06, 2009 9:14 pm
You could try this .They made one for my Rickman around 1988 .
www.bandcexpress.co.uk
Users browsing this forum: Bing [Bot] and 105 guests
