Z750 Race Bike
Z750 Race Bike
#1 PostAuthor: #88 » Tue Sep 08, 2009 7:01 pm
My latest project.Having raced a variety of bikes from single cylinders(Tigcraft H****,Hejira Suzuki,TZR125RR with an XBR500 motor),a couple of old zeds,CBR 600,Yzf 750(first highside-flat out in 3rd :cry: ) and my last bike a H**** K4,I decided to have a break from the racing.That was until my Dave offered me his old 750 earlystock,I couldn't resist it.It needs a bit of work to put it back on the track but its got some nice bits-Metchamex swing arm,Koni shocks,Goodridge,steering damper,Micron brace,raask rear sets,brand new Avon race tyres.Going to fettle it up over the winter for next season.Will update throughout the winter.
cheers the noo Brian #88 2Bz's racing
#2 PostAuthor: Pigford » Tue Sep 08, 2009 9:07 pm
Very nice...... Keep us up to speed with this beasty :twisted:
#88
#3 PostAuthor: #88 » Tue Sep 15, 2009 6:50 pm
Here's a couple of fotis of the Zed.I'm building it on a budget(not got pots of cash).It'll not be concours but there is a good chance it might get chucked up the track :wink:
[url]Image
Image[/url]
#4 PostAuthor: chrisNI » Tue Sep 15, 2009 9:31 pm
Looking good already...
#88
#5 PostAuthor: #88 » Fri Oct 02, 2009 6:35 pm
Been a bit quiet on the bike building front,was on holiday to Scarborough and managed to take in the Gold Cup at Olivers Mount.Would love to have a run round there when I finish off the Zed.Getting there slowly,got a cracking set of forks from a local breakers(gs500 rear wheel and 20quid :D ).Will make a start on them tomorrow and hopefully get the bike back on its wheels.
cheers the noo Brian #88 2B'z Racing
Magnum1
#6 PostAuthor: Magnum1 » Sat Oct 03, 2009 7:34 am
Looks nice and uncluttered. I see you are running CV's, how do you get on with setting them up? Are you using a dyno or road testing?
Rod
Never heard of a Harris Magnum
#88
#7 PostAuthor: #88 » Sat Oct 03, 2009 8:39 pm
The previous owner had the head done and the carbs rejetted and set up on a dyno,think it was making about 70 brake.
Baz Swailes
#8 PostAuthor: Baz Swailes » Tue Oct 06, 2009 11:54 am
I raced a Z 750 L4 in Earlystocks for a few seasons.
I ended up with a broken leg but don't regret doing it as it was great fun.
I will try and dig out some photos of the bike.
BAZ
#88
#9 PostAuthor: #88 » Fri Oct 09, 2009 6:10 pm
Treated the Zed to a new shed,waiting on it getting delivered next week.Using one of those metal sheds at the moment(leaks,drips condensation,cold) not ideal.Got a sump gasket the day,going to whip the sump off and check the strainer as I ran a big end in a second hand motor a couple of years ago,it only lasted 1 practice,1 qualifing and shit itself half way round the warm up lap :( (took the motor to bits and found the pick up full of crud-lesson learned).
#88
#10 PostAuthor: #88 » Mon Oct 12, 2009 2:59 pm
Had to put the wheels on the bike to make it mobile,before the new shed arrives
cheers the noo Brian #88 2B'z Racing[/img]
#88
#11 PostAuthor: #88 » Mon Nov 02, 2009 7:23 pm
The new shed arrived and was finished in about 2 days.Now that I have somewhere reasonably warm but above all dry its time to start working on the bike.Over the last couple of weeks the forks have been stripped/seals changed/15wt oil used/17mm preload spacers fitted.Turned a couple of sleeves on the lathe so I can fit fork gaitors and micron brace(the gaitors aren't everyones cup of tea but thet serve a purpose).Fitted forks to yokes.
Rebuilt calipers fitted race pads,lock calipers,bled brakes,fitted mudguard.Will post a couple of fotis at the weekend.
#12 PostAuthor: chrisNI » Fri Nov 13, 2009 4:52 pm
It's looking good already - you need to lose the green background on the Z750 badge but that's just being picky... Do you have to stick with the standard brake calipers?
#88
#13 PostAuthor: #88 » Sat Nov 14, 2009 8:27 pm
Hi Chris,never thought about the badges,I've kept the standard calipers and discs,its got briaded lines,dot 5.1 fluid,sintered pads,rebuilt calipers(seals/piston in one caliper) and a NC30 master cylinder.
Cheers the noo Brian #88 "Once You've Had A Kwack Theres No Going Back"
#88
#14 PostAuthor: #88 » Thu Nov 19, 2009 8:55 am
Hi there
I,ve changed the title of this post.At first I thought my bike was a GPZ750R1,but the more I work on it I think it is a late model L4.It has a different CDi same as the uni-trak,the thing that was throwing me was the frame number R1.Anyway just going to call it a Zed :wink: .
fuknuckle
#15 PostAuthor: fuknuckle » Thu Nov 19, 2009 7:50 pm
I like this, good to see another race bike being built, is that a H1 ZXR 400 rev counter? :D
If its not broken, fix it till it is
Users browsing this forum: j.wilson and 183 guests
