brake pistons - where? how much?
02GF74
#1 PostAuthor: 02GF74 » Wed Sep 09, 2009 7:49 pm
took pistons out the back caliper and I guess ideally they should be replace but they are usable.
... so am I looking at an arm and a leg price :shock: or does someone sell generic pistons; obviopulsy they need to be same size;
mesured:
42.8 mm diameter
overall depth 21.7 mm
seal depth: 17.2 mm (this is the bit beyond the step that runs against the seal).
lta01
#2 PostAuthor: lta01 » Wed Sep 09, 2009 9:07 pm
Z power do them, and I'm pretty sure that there are some generic copies available through the bike trade. Some come with the seal, think £20-odd quid a piston from memory.
Alternatively, there is a guy called Mark Copley who advertises in the VJMC white book , he's in Yeovil , and he will make you replicas in stainless, for £15 each plus postage. You send him the old ones, he sends back lovely new ones a couple of weeks later. ( I'll try to find his contact details if some else doesn't beat me to it )
I've used him on most bikes I've restored, and he does a good job. He does NOT polish the pistons, just fine mills them. It tends to make pistons a little slower to move out and take up pad wear, so lever travel becomes a bit longer, then one day the piston travels far enough to slide on the seal, and lever is back at full firm. Alternative is every 3 months, take caliper off, pump lever once, ease caliper back on , job done. worth every penny to avoid ever having to replace them again. Don't forget to clean out the caliper groove fully, I use a brass radial brush in a dremel....gently.
He who dies with the most toys wins .
PJ
#3 PostAuthor: PJ » Wed Sep 09, 2009 9:29 pm
Hi matey,
You did not say what bike - but these guys are very good
http://www.wemoto.com/pictures.dyn?u=1914614qqq3395473
sweptail
#4 PostAuthor: sweptail » Wed Sep 09, 2009 11:14 pm
There is a guy from the north east who is a member on here.
i sent my old piston and he machined two for me;good quality, stainless.
They have been on the bike for over a year now with no probs. I think his name was Terry. Maybe he will make himself known after reading this thread.
Very reasonable too.
Tommy :)
02GF74
#5 PostAuthor: 02GF74 » Wed Sep 09, 2009 11:44 pm
z1000 a1
PJ
#6 PostAuthor: PJ » Thu Sep 10, 2009 6:50 am
02GF74 wrote:z1000 a1
This is for A1 / A2
02GF74
#7 PostAuthor: 02GF74 » Thu Sep 10, 2009 7:41 am
thanks for your help - will try to find Mark Copley as £ 15 sounds a good price; will give the other chap a call.
