HOW WAS THIS HEAD CLEANED
Can't see the images Barrie, please re submit.
But
Best cleaning results are by vapour blasting or vapour blasting then burnishing- See link to Steve Smethurst, fantastic results, never heard a bad review of his work and loads of guys in Z1OC have used him (inc myself)
But
AKA John Roscoe. PUM #028
1975 Z1B, 1980 Yamaha 350LC
Baz,
OBR's A4 cylinderhead and barrels were definately vapourblasted.
If your considering having this done you really need to strip the motor, our kid bought a Z1B that was excellent, the motor had been vapour blasted by someone without stripping it (god knows how he sealed it to prevent grit entering the bowels). Finish was great but when I changed the tacho drive oil seal I found grit in there, luckily it had not migrated into the cam area.
ENGINE
Z1 BARRIE
IF YOU TAKE A LOOK AT MY Z1B ( HOBBOS RESTORATION ) THIS IS THE RESULT OF STEVE SMETHURSTS WORK ON ENGINE FINISHING TOP NOTCH WORK AND YES YOU DO NEED TO STRIP ENGINE .HE REMOVED THE ENGINE STUDS COZ THEY WHERE A BAS...D
PHIL
PHIL
International Rep
International Rep
Z1Barrie
Users browsing this forum: No registered users and 122 guests
