Running on two
JohnJ
Running on two
#1 PostAuthor: JohnJ » Mon Sep 14, 2009 9:29 am
Hi, my z1000 dropped onto 2 cylinders on the way to work this morning, it's lost the outside 2. I swapped the plugleads outer for inner and swapped the trigger wire to the coils and the other coil will work the middle cylinders so it's not the coil. It's got a dyna s ignition which all looks ok under the cover. Any ideas? The Dyna s is less than 2000 miles old.
Cheers, John.
PJ
#2 PostAuthor: PJ » Mon Sep 14, 2009 11:12 am
Hi John,
You did not say if you checked the plugs themselves?
Worth a try if you have not already
JohnJ
#3 PostAuthor: JohnJ » Mon Sep 14, 2009 11:38 am
Yes, checked the plugs. All ok. I think the Dyna s sensor for 1 & 4 must be shot.
#4 PostAuthor: chrisu » Mon Sep 14, 2009 1:27 pm
wire not come loose perhaps .................
have you had the tank off to check ?
JohnJ
#5 PostAuthor: JohnJ » Wed Sep 30, 2009 11:02 am
Well I narrowed the fault down to the Dyna S sensor on the crank. Dynatek are the agents so I rang them. I told them that it was 2 or 3 years old but only fitted recently and they said send it to them for testing.
They have sent me a new one free of charge.
Big thankyou to Dynatek!!
Buy some stuff off them!!
John.
