Z1-R engine strip down report
HowieD
#1 PostAuthor: HowieD » Wed Sep 23, 2009 4:55 pm
Aye up !
Sent my engine off for overhaul - 1980 60 odd thousand miles, this is what need doing according to the feedback:
re-shelling the cams
grinding in valves with new stem seals
full gasket set (genuine)
ignition system missing- please advise
new cam chain
new plastic wheel for double wheel chain guide
tensioner/chain guide damper rubbers
repair 1x starter motor bolt(snapped)
1x main crank retaining bolt snapped on disassembly-easy fix
hone the bores
re-ring pistons
skim head
paint cases
the gear box is mint as you predicted-amazing.
Ignition is sat on a shelf in my shed, I think an alternator winding is duff as well and awaiting feedback from that.
But that's it - what do you recon?
Apart from why aint i doing it myself!!! - I work away most of the year and dont have time
regards
Hx
stephen parr
#2 PostAuthor: stephen parr » Wed Sep 23, 2009 11:17 pm
Sounds about right to me mate.
Those are all the things I replaced on my Z1R engine with similar mileage. :wink:
stephen parr
#3 PostAuthor: stephen parr » Wed Sep 23, 2009 11:21 pm
Oooops forgot, I had my valve guides replaced aswell. :)
