confirm z1000-a1 carb part numbers?
02GF74
#1 PostAuthor: 02GF74 » Sat Oct 10, 2009 4:30 pm
looks like I need new needle vsalve - it drips a bit, reckon the spring is too weak.
I have z1000 A1, according to haynes: VM 26 SS
on allens website, closest that look like mine are VM29 carbs.
assuming that is correct, please can someone confirm part number?
22 B34/52-0.0 Gasket: Float Valve Assy
23 N122032-size Float Valve Assy
what is the size??
but on the Mikuni Float Valve Assembly Chart, there are quite a few listed for VM26 ... and the number does not match the above/ :evil:
HELP?!?!?!?
am I best sending off the pasts to them?
#2 PostAuthor: chrisu » Sat Oct 10, 2009 4:35 pm
have a chat with NRP in Manchester.........
tlc
#3 PostAuthor: tlc » Sat Oct 10, 2009 5:30 pm
16030-027 is the Kawasaki part number.
Many rebuild kits are available and A1 or A2 use the same part.
