z1r tyre pressures
watty
z1r tyre pressures
#1 PostAuthor: watty » Thu Oct 22, 2009 12:01 pm
Anybody help with tyre pressures for my z1r which has 18inch front and rear tyres. Bike handling like a pig at 80mph. Any ideas
PJ
Re: z1r tyre pressures
#2 PostAuthor: PJ » Thu Oct 22, 2009 12:33 pm
watty wrote:Anybody help with tyre pressures for my z1r which has 18inch front and rear tyres. Bike handling like a pig at 80mph. Any ideas
Z1R's do that standard,
.Sorry watty I do not know the answer, but I'm sure one of our many Z1R owners will let you know asap
PJ :D
Kev1R
#3 PostAuthor: Kev1R » Thu Oct 22, 2009 2:59 pm
I have always stuck with Front 28 and rear 32psi
Metzeler Tyres
No problems
(Increase rear pressure up to 35-36 if carrying pillion)
phil churchett
#4 PostAuthor: phil churchett » Thu Oct 22, 2009 6:47 pm
It's also worth checking steering head bearings and swinging arm bearings for play. [and wheel bearings too].
Donaldson
#5 PostAuthor: Donaldson » Fri Oct 23, 2009 12:36 pm
I have BT45 tyres on my Z1-R and run 38 in the back, that go rid of a lot of problems, but you should check the shock's, i also put progessive springs in the front, just the hinge in the frame to sort out next.
02GF74
#6 PostAuthor: 02GF74 » Fri Oct 23, 2009 5:19 pm
Z1RT311 wrote:I have always stuck with Front 28 and rear 32psi
exactly what he says.
stephen parr
#7 PostAuthor: stephen parr » Sat Oct 24, 2009 9:50 pm
Agree entirely with all of the above regarding pressures and bearings. Mine handles fine. Got steering damper on but not really sure if that's contributing anything or not. Got taper roller bearings in the steering head also. :)
tlc
#8 PostAuthor: tlc » Sun Oct 25, 2009 6:34 am
Back to the question of tyre pressures..........................................
........................Stephen Parr recommends 0psi for fantastic MPG :lol:
stephen parr
#9 PostAuthor: stephen parr » Mon Oct 26, 2009 9:47 pm
Excellent Chris! :lol:
Still, a bit cruel though :P
