Engine No
MARK GB
Engine No
#1 PostAuthor: MARK GB » Sat Oct 24, 2009 4:29 pm
Hi can any body shed any light on this engine no Z1E963231. Recently had a few comments on it as it may be wrong any information would be helpfull.
thanks Mark.
000zeds
#2 PostAuthor: 000zeds » Sat Oct 24, 2009 4:48 pm
Think it is a Z900 engine which started at Z1E-086001 but don`t know what number they finished at before Z1000s.
Zeds-R-Us
mick znone
#3 PostAuthor: mick znone » Sat Oct 24, 2009 6:33 pm
could it have been restamped by an amateur
Garn 1
#4 PostAuthor: Garn 1 » Mon Oct 26, 2009 8:58 am
Mark. I had a Z900-A4 with a frame number Z1F-095516, manf 10/75, with an engine number Z1E-099938, Your number engine ZIF-963231 with this number of digits, sounds like it came out of the Nabraska...
There was a Z900 frame manufacture in Nabraska about 11/75 with a frame number starting at about Z1F- 970000. This could be a matching engine for this series...
RegardZ.
PJ
#5 PostAuthor: PJ » Mon Oct 26, 2009 10:20 am
This info comes from Z1 Enterprises website
Z1 engine and frame numbers
All Z1 & KZ900 frame numbers are stamped on the steering head. Additionally, in the USA & Canadian market, there is a white sticker on the steering head showing the frame number and the date of manufacture. The frame numbers will be in the following ranges
1973 Z1
Z1F-00001 through Z1F-19999
1974 Z1-A Z1F-20000 through Z1F-47499
1975 Z1-B Z1F-47500 through Z1F-85700
1976 KZ900-A4 Z1F-85701 through Z1F-13xxxx for bikes manufactured in Japan
1976 KZ900-A4 & 1977 KZ900-A5 Z1F-500001 through Z1F-51xxxx for bikes assembled in Lincoln Nebraska
Z1 & KZ900 engines have engine numbers stamped on the top right side crankcases on a raised area over the clutch. The engine numbers follow the same general range as the frame numbers. Frame and engine numbers were not matched at the factory, although most frame / engine number combinations are within 200 numbers. Most bikes have the engine number higher than the frame number, but this is not always true. We have records showing new bikes sold where the engine number is less than the frame number - although this is fairly rare.
While the frame and engine numbers are the best indication of the model and whether the engine has been replaced, these are not the only numbers to help validate an 'authentic' Z1.
PJ
#6 PostAuthor: PJ » Mon Oct 26, 2009 10:23 am
This is from Zpower site
1974 Z1-A
FRAME NUMBER: Z1F-020001 >
ENGINE NUMBER: Z1E-020001 >
COLOUR: CANDYTONE BROWN/ORANGE OR CANDYTONE GREEN/YELLOW
Major changes for this model were the silver engine finish, redesigned tank and tailpiece markings and a stop lamp failure light in the tachometer. The idiot light cover was also changed, the warning lights were now placed in a different order. The best gets better.
1975 Z1-B
FRAME NUMBER: Z1F-047500 >
ENGINE NUMBER: Z1E- 047500 >
COLOUR: CANDY SUPER BLUE OR CANDY SUPER RED
Major changes for this model were paintwork and markings, larger side panel badges and the adoption of an 'O' ring chain instead of the previous built in chain oiler. The switchgear was slightly cosmetically changed and the Speedo was now in 10-mph increments. The fuel tap was changed from black to silver and the carbs were modified to improve performance.
1976 Z900-A4
FRAME NUMBER: Z1F-085701 >
ENGINE NUMBER: Z1E-086001 >
COLOUR: DIAMOND DARK GREEN OR DIAMOND BROWN
Major changes for this model included colour and marking, different side panels and badges, airbox, twin front brakes, locking fuel cap, three way fuse system, hazard warning lights, audible flasher indicator, square tail light, improved instrument cluster and a change to smaller 26 mm carbs. Power was down to 81 bhp but the Z900 was a much better bike to ride. A few extra models
rolled off the American production line in Lincoln in 1977 known as the KZ900-A5.
MARK GB
#7 PostAuthor: MARK GB » Fri Nov 06, 2009 3:13 pm
Hi thanks for all the help.but at the moment still non the wiser this is the chassis no Z1F48472 / Engine no Z1E963231 / Reg AVS 274N I don't think they match up as far as I know the engine was changed over just befor I got it. Any information or history of the bike would be helpfull.
Thanks Mark.
phil churchett
#8 PostAuthor: phil churchett » Fri Nov 06, 2009 4:39 pm
Mark, you bought this off Rob? [can't remember his last name].
I saw him at Stafford and had a natter with him. May have some contact details for him somewhere.
MARK GB
#9 PostAuthor: MARK GB » Sun Nov 08, 2009 5:44 pm
Thanks Phil let me know if you find any contact details his name is Rob Beal or something like that.
thanks Mark.
RB
Mine's a triple!
#10 PostAuthor: RB » Sun Nov 08, 2009 9:09 pm
Is the bike an Import ? I'd suspect it is from the Reg number, and I also suspect that the engine is also of U.S. Origin - The correct engine would have been within a couple of hundred number of the frame ?
Lifes too short . . .
tm53chev
how about an engine with only 5 #
#11 PostAuthor: tm53chev » Tue Nov 10, 2009 1:32 am
one is Z1E-00390 is this a 72/73?? another is Z1E-16673?? 1973??
MARK GB
#12 PostAuthor: MARK GB » Tue Nov 10, 2009 5:37 pm
Hi you were right it is an import came to the UK 27/3/1990 also according to the log book it was first manufactured 1975.
thanks Mark.
Steve Cooke
#13 PostAuthor: Steve Cooke » Tue Nov 10, 2009 11:12 pm
Mark are you sure the first number on your engine is a nine? could it be a zero? and although It's not relevant to you but I think the two hundred-ish difference between engine and frame numbers isn't the case on the Z900A4's other than the real early ones, possibly due to the engines taken for the Ltd models but I stand to be corrected.
Anyway you may find this helpful:-
http://www.kawa-z1.com/technics.shtml
phil churchett
#14 PostAuthor: phil churchett » Wed Nov 11, 2009 7:50 am
MARK GB wrote:Thanks Phil let me know if you find any contact details his name is Rob Beal or something like that.
thanks Mark.
Sorry Mark, i can't find his number.
You are right, his surname is Beale, he did have his own plumbing/heating business, based in Lichfield. Oddly enough, i hadn't seen him for ages, yet saw him twice this year, at different events.
It's worth asking Jerry if he has any contact details for him.
MARK GB
#15 PostAuthor: MARK GB » Wed Nov 11, 2009 6:37 pm
Hi Phil I rely don't want to get in touch with rob if I can help it.When he delivered the the bike to my house there was a few parts that had been changed over from when I seen it the first time gave me a load of bullshit as to why had changed the parts over. changed the exhaust and took an oil cooler off so you can see why I don't want to get in touch.
thanks Mark.
PS thanks for the link Steven.
