Got a scrap head and thought id have a go at polishing the ports,
what are you trying to achieve, is it to smooth out the port with out
taking off to much material? and do you do both inlet and exhaust ports?
porting
Mikey - This is a real "black art"
The inlet ports are the crutial areas - too smooth & it can reduce power - coz the air/fuel mix won't .... err, MIX properly.
The exhaust ports are less critical and you can polish away
Just matching ports/manifolds/headers is a good start, remove any lumps & bumps & give it a go
http://www.popularhotrodding.com/engine ... index.html
Here's an interesting article Mikey. Not too much on the theory stuff but a practical approach for guidance purposes.
from memory what I was taught over 30yrs ago was to think air flow and moving volume of air, opening up tapers, removing ridges, and to leave the surface rough because it creates turbulence, there is no point opening up the carb & exhaust ends of the ports if you get this effect >< what you really want is this == if you get what I mean.
While I do agree with what pigford said about matching mating surfaces at inlet and manifold, it is the valve end of the port which is the important end.
I know tapers create pressure but ya can't beat volume/flow.
Don't bother starting with a dremmel either. you will be there for weeks.
Just my tuppence worth.
Baza
