Front Master cylinder A2
breakdown
I've got a master cylinder for my A2, which I was told had come from an A2. The cylinder looks correct, right shape and going from the diagram in the manual, identical part for part. When I went to order the repair kit I noticed that the dia of the piston is 14mm. Is this correct for a twin disc set-up. If not, any idea's what it might be from. Any info gratefully appreciated. Thank you
breakdown
breakdown
