z1000r/j/gpz parts
z1000r/j/gpz parts
in need of a bottom yoke from a gpz1100b1/b2/j/r , also would like a complete set of engine mounts for above as i have a frame which has had mounts removed originally for a gsxr1100 engine , so i could do with the original's spacers if possible i then can re install the proper engine , have a long way to go but this would help thanks gary.
- london calling
Gazza,I'm pretty sure there are different offsets for the fork yokes between the B1/B2 as well as the J and R models.
May well be worth your while checking the part numbers for the various models as it will save you finding out the hard way like what I did
The J1/J2 and B1 top yoke has the ignition mounted to the L/H/S,whereas the B2/J3/R2 is in the centre.
Jack
