Speedo Drive Bushing Question
#1 PostAuthor: ZedHead » Sun Nov 22, 2009 10:47 am
Hi, the thread on my speedo drive cable bushing is slightly damaged. A replacement bushing is available relatively cheaply, but it is held in to the housing with a spring pin that is inserted one way, there isn't a hole on the other side to drift it out.
Has anyone had any experience and therefore got any tips on how to extract this pin?
breakdown
#2 PostAuthor: breakdown » Mon Nov 23, 2009 10:55 pm
Hi Zedhead, You've probably guessed by now, but I'm afraid if there is no way to drift it out, it's going to have to be drilled (very carefully). It's a very short spring pin so not to far to drill. Best of luck.
#3 PostAuthor: ZedHead » Tue Nov 24, 2009 6:55 pm
breakdown wrote:it's going to have to be drilled (very carefully). It's a very short spring pin so not to far to drill. Best of luck.
Drat and double drat, Mutley.
Oh well thanks anyway, I think i'll build up to that one :shock:
