Fork Brace
C Martin
Fork Brace
#1 PostAuthor: C Martin » Sun Nov 22, 2009 8:26 pm
wanted for a z650, either micron or teleflex, Thanks
Chris
Big Fluff
Re: Fork Brace
#2 PostAuthor: Big Fluff » Thu Nov 26, 2009 2:14 pm
C Martin wrote:wanted for a z650, either micron or teleflex, Thanks
Chris
Chris.
Nothing listed for 70's Zeds but then again neither was one for my 94' VS800 Intruder and they had one to fit, so they may well be worth a call, like I did.!
'Superbrace' has to be the ultimate in fork braces. The quality and fitment is outstanding mate.
http://www.superbrace.com/proddetail.asp?prod=4443
Good luck, Will
C Martin
#3 PostAuthor: C Martin » Thu Nov 26, 2009 10:09 pm
thanks Will, if nothing turns up i might give them a try
Chris
KeithZ1R
#4 PostAuthor: KeithZ1R » Fri Nov 27, 2009 8:02 pm
Chris what diameter are the legs :?:
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
C Martin
#5 PostAuthor: C Martin » Sat Nov 28, 2009 9:13 pm
hi Keith, the fork leg tops are 56mm and the distance between the forks center to center is 190mm
Chris
