Z1000J GPz1100 Frame
#1 PostAuthor: Ginger Bear » Mon Nov 23, 2009 3:53 pm
Before I get started on my next little project, I thought it might be worth trying to source a better frame than I have at the moment. This frame needs a V5 (£25.00) and this mess sorting out. Just thought it might be a better option to start with a good frame, before I start chucking time & money at this one!
mick znone
#2 PostAuthor: mick znone » Mon Nov 23, 2009 6:02 pm
you sure thats not a ford transit frame Bear :o
#3 PostAuthor: Ginger Bear » Mon Nov 23, 2009 6:38 pm
No Mick. Is that what yours looked like?
Keefleaf
#4 PostAuthor: Keefleaf » Mon Nov 23, 2009 8:54 pm
You`re about to get P.M :)
#5 PostAuthor: paul doran » Mon Nov 23, 2009 8:59 pm
that is fairly nasty
531johns
#6 PostAuthor: 531johns » Mon Nov 23, 2009 9:22 pm
that is very nasty, whats the rest of the bike like??????
Robw
#7 PostAuthor: Robw » Mon Nov 23, 2009 9:29 pm
Hi, I got a frame from John Browse in Wrexham, top bloke, although expensive if you want a Z1000R frame.
Rob
#8 PostAuthor: Ginger Bear » Mon Nov 23, 2009 10:06 pm
531johns wrote:that is very nasty, whats the rest of the bike like??????
Rest of the bike is very good, been pulling it apart tonight. Everything is well greased & pretty much corrosion free.
This is I believe a common fault on the Z1000J. I think what must happen is water gets into the frame, then when it's parked on it's side stand, the water runs to the lowest point, then rots from the inside out :cry:
mick znone
#9 PostAuthor: mick znone » Mon Nov 23, 2009 10:07 pm
Ginger Bear wrote:No Mick. Is that what yours looked like?
absolutely Bear, a right mess. i recon that frame needs to go to the great frame whole in the ground. good luck finding another. :up
#10 PostAuthor: Ginger Bear » Wed Nov 25, 2009 3:19 pm
Robw wrote:Hi, I got a frame from John Browse in Wrexham, top bloke, although expensive if you want a Z1000R frame.
Rob
Spoke to John Browse........................ £275.00 + Delivery :no :no :no OUCH!
#11 PostAuthor: Ginger Bear » Thu Dec 03, 2009 10:41 pm
Still looking :shock:
kano
#12 PostAuthor: kano » Thu Dec 03, 2009 11:25 pm
kz1000r frames go for a $1000 bucks here.....
i live free and ride in the states but i am British and bloody proud of it!
http://www.kz1000r.com/
#13 PostAuthor: Ginger Bear » Fri Dec 04, 2009 7:34 am
kano wrote:kz1000r frames go for a $1000 bucks here.....
:shock: :shock: :shock: :shock: :shock:
Peter
Z1000J frame
#14 PostAuthor: Peter » Wed Dec 16, 2009 2:46 pm
Hi, I have a good Z1000J frame complete with V5. The only thing that needs doing to it is the front engine mount needs re-fitting. I intended to fit an earlier engine, so had the front mount (where the rubber mounting fits) cut off and welded back on at the rear to form an extra engine mount there. Should be pretty straightforward to move it back if you can weld! You can have it for £100, but no idea how to send it!
I work at Heathrow if you can collect?
Regards, Peter.
Peter (ex Z1000R2 owner)
#15 PostAuthor: Ginger Bear » Wed Dec 16, 2009 4:30 pm
Peter, Just sent you a PM
