yet another build in the works
tm53chev
#1 PostAuthor: tm53chev » Mon Nov 23, 2009 6:00 pm
picked up a stripped down 78 Z frame with a 74 Z1E 900cc bone stock engine with 18K on the odomiter. frame neck is cut, braced and set at a 38deg rake. have installed a custom built 8 "over rear swing arm. 160 rear tire, 94" over all length, custom built rear fender, 3 stage fully adj 75hp max NOS kit to install, back cut trans, ceramic coated piston tops to withstand the NOS and NOT burn a hole in the piston, shift light, gear indicator, fully adj drag race electronic ignition, front air damn, floor boards. will be all black paint job, custom aluminum rims, stainless brake lines and anything else I can pull off the shelf for some bling(chrome). need help again posting pics...anyone willing to help out an inept PC user here???
tlc
#2 PostAuthor: tlc » Mon Nov 23, 2009 6:09 pm
tm I would suggest you put this in the projects section.
I will gladly help you put up piccies but it is really easy to do yourself.
PM sent with email address if you like to send me pics `til you learn how to...
Alexander
#3 PostAuthor: Alexander » Mon Nov 23, 2009 8:10 pm
Hi tm,
welcome to the club, fairly newby myself so returning the good welcome I recieved when introducing myself here for the first time. I look forward to seeing the pics of your sled, sounds a great project. Alex.
Administrator
#4 PostAuthor: Administrator » Sat Nov 28, 2009 6:32 pm
Moved to projects.
In the Valley of the Pissed the half cut man is King
Users browsing this forum: j.wilson and 120 guests
