Creaky clutch
TheBogieMan
Creaky clutch
Am I the only one that suffers from this ?
Has anyone got any suggestions on what will keep the worm screw lubricated for more than a couple of months ?
Speed Triple 955i, Yamaha RD350A, BMW F800S, Harley FLSTCi
- DogsbolloxofZ1B
Rich, do you mean the one from a Mk11 engine?
TheBogieMan, where is it creaking mate
At the lever or down the business end (engine).
If at the lever try a bit of oil. Best to oil the cable regularly anyway, especially as its prone to road sh*te at the bottom end.
Check mthe cables not heat damaged where its close to the exhaust, halfway down!
TheBogieMan
TheBogieMan
Hi,
this might seem like a stupid question but are you sure your lifter is a worm?
I have a J which has a ball and ramp system whose adjustment mechanism is 100% the reverse to the worm and most manuals don't mention it. The creaking as you described happened on my J but worse, on a number of occasions the clutch jammed in declutch position as the lever over rotated.
being a thicko I diligently followed the Clymer manual adjustment process, only when I took the mechanism apart and saw how it worked did i realise the manual only covered the worm system. The ball and ramp system is "unscrew until resistance and then clockwise 1/4 turn"
TheBogieMan
It's deffo a worm Kiwiz, mines a 75 Z1B...had the clutch worm off more times than I care to mention
Thanks for the pics Rich, will now have to start trawling places to get one now, I was starting to think I'd have to get a bit machined up in PTFE
As for the dung Davey.....you aint wrong there, tis spreading season again, I'm currently riding around with a magic tree inside my lid
