Z1R Oil
dave m
Z1R Oil
#1 PostAuthor: dave m » Mon Apr 09, 2007 4:45 pm
Hi,
Can anybody please recommend a good make of engine oil and brake brake fluid for a 78 Z1R as I,m about to the bikes first service since I,ve owned it.
Also are the oil and air filters advertised on ebay ok to use.
regards
Dave :D
#2 PostAuthor: Pigford » Mon Apr 09, 2007 4:50 pm
Dave M, do a 'search' mate, theres a ton of info (some quite recently) on this subject. :wink:
Most modern mineral oil seem OK in a Zed. Full synthetic may lead to a slipping clutch :?: :shock: But not always :!:
Main thing is regular oil & filter changes (I use top quality mineral - Kendalls or Amsoil and change oil & filter max 1500 miles) and you can't go too far wrong :D
Padders
#3 PostAuthor: Padders » Mon Apr 09, 2007 5:10 pm
I use Silkolene Super 4 10w 40 its a semi syn oil and works fine. No problem with the e bay filters if you are doing regular oil changes.
padders
london calling
#4 PostAuthor: london calling » Mon Apr 09, 2007 6:30 pm
I use Rock Oil TRM 20/60 which is specifically formulated for roller bearing crankshaft engines.
I only use genuine Kawasaki oil filters in my 1000J type motors as they are cheap anyway.
Jack
